It's not a challenge at all, it's just an act of utter stupidity. Where's the challenge![]()
It's the mentally challenge.
Natural selection at work.
Darwinism at work.
Around 15% of the population will score less than 85 on an IQ test.
How to kill yourself for under a quid!
kill yourself for free with the water challenge. yes you really can die from drinking to much water in to short a space of time
Isn't that how E kills people? (IE Not so much drug toxicity but water toxicity from the uncontrollable thirst that E use can produce)
I have a water meter![]()
Mostly, E kills people by the E they buy not actually being E, but rather something rather toxic (effects of prohibition)
Leah Betts, famously (notoriously?), died of excessive water consumption. It doesn't happen often, though.
This is all correct. MDMA is actually a pretty safe chemical, it's the other crap it's sometimes cut or mixed with and too much water that usually cause problemsLeah Betts had taken proper MDMA though. Not something else. Her water intoxication came about because of paranoia of not drinking enough water while on E. So she chugged a load and the effect of E makes it harder to pass urine. So she doubled the causes of water intoxication by drinking too much in a short period of time and not being able to ****, retaining a brave chunk of what she was taking in. You don't even need to be taking E to give yourself water intoxication. People exercising can inadvertently give themselves water intoxication by over hydrating while working out.
The "toxic" MDMA sold is usually research chemicals passed off as being proper MDMA. Or MDMA cut with other drugs, such as ketamine. The really trippy pills are the ones usually cut with ket. Back in the day I had many trippy pills and the effects on you are more like sinking into the K hole than riding high on E.
Maybe this is being done with the aim of getting that closer to 10%
Almost all "E" tablets are contaminated since pure MDMA can't be formed into a pill. It needs a filler to hold it together as a pill. Which is usually drugs like ket or amphetamine. Pure MDMA only comes in crystal form.
