They have equal length headers = no rumble... i have the same engine
Are you sure about that? According to wiki the 4U-GSE* is only used in the GT-86 and FR-S, and the FA20D* is only used in the BRZ, it seems unlikely Toyota would let Subaru put it in the WRX...
*Same engine with different names if it's in a Toyota/Subaru.
ok, another question, as my cat is done for, is it against the law to drive a car without one, I'm thinking I'll run a straight pipe until I have enough cash to change the whole thing and get a new cat fitted.
Pretty sure you're wrong.
If a car has a cat as standard, it's part of a MOT check to make sure it's there. Well post 1992 IIRC.
Expected far more flaming in this thread....
lol, only reason i'm doing it is because the cats had it and need a new one so thought i'll try and get a nice sound while at it.
Edit: found this, might give it ago https://www.funkypower.co.uk/catalo...=UNIVERSAL+BACK+BOXES&level3=&id_product=5630
He's after the exhaust note, a flamer kit won't really help much.
All these people who think it's the boxer engine that makes the sound are rather wrong, it's the unequal length headers that do it, any 4 pot can sound like it with the right header configuration.
That will do the job.
Note that its a universal back box though and not a bolt on, you will have to get this welded in. I noticed that you don't want to spend a fortune so if you head over to ebay you can pick these up for £30-40. Gives you a bit more towards the cat. Also that comes with a bolt in silencer which is basically a bung which will reduce the size of the exit hole, these are pretty affective at reducing the booming noise.
Not sure that's quite correct - the flat 4 and manifolds make the sound from what I understand
Take that s2000 video on the previous page as an example, it just sounds a bit broken.
From memory an inline 4 can never sound quite the same due to the firing order vs the side by side order of the boxer
OK you can stick unequal length manifolds on anything, but it'll probably sound rotten and cost rather a lot
I think you're right in that respect, but my understanding is that it's the layout lends itself to a certain firing order which in turn creates the sound?
