** INSANE PAY DAY THIS WEEK ONLY DEALS (RAM, SSD, GRAPHICS, MONITORS ETC)!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
It has being quite a long time since we promoted some epic crazy deals on the forum and I hope to not disappoint with the following deals which should be the best prices in the UK on some of the products and some of them are absolutely insane like a 1440P monitor at £199 inc, so be sure to check them all out below:
adata xpg z1 16gb (4x4gb) ddr4 pc4-19200c16 2400mhz quad channel kit (ax4u2400w4g16-qrz) @ £139.99 inc vat
adata xpg z1 ddr4 overclocking memory is designed as the ultimate upgrade for overclockers, enthusiasts, and gamers thanks to its remarkable performance and power efficiency. even with speeds of up to 2800mhz and a transfer bandwidth reaching up to 22gb/s, xpg z1 consumes 20% less power when compared to ddr3. utilizing thermal conductive technology and 10-layer pcb with 2oz of copper, xpg z1 provides excellent cooling performance, as well as great stability whether you are on the battlefield gaming or trying to achieve higher benchmarks while overclocking.
ddr4 outperforms ddr3 with improved performance and lower power consumption. the operating voltage has decreased from 1.5v to 1.2v, which is a 20% reduction of power, and keeps the system at a low temperature for stable operation. it only requires 1.2v to achieve high clock frequency of 2800mhz for overclockers. additionally, the spd (serial presence detect) of xpg z1 allows direct application without changing settings in the bios, facilitating usage and system stability.
the jet wing-inspired design of xpg z1 combines the carbon texture used for race cars, symbolizing the pursuit of extreme performance. it also features excellent cooling and stable data transfer due to thermal conductive technology and 10-layer pcbs with 2oz of copper to effectively reduce electric resistance and consume less power, which greatly enhances the quality of signal transfer.
xpg z1 ddr4 dram module is made of high-quality chips selected through a strict filtering process. it also uses the top quality pcbs (printed circuit board) that effectively extend the lifespan of memory modules.
specification:-
- cpu compatibility: intel haswell-e ( lga 2011-3 )
- chipset: intel x99
- capacity: 16gb (4gbx4)
- quad channel kit: yes
- tested speed: ddr4-2400 mhz (pc4-19200)
- tested latency: 16-16-16-35
- tested voltage: 1.2v
- registered/unbuffered: unbuffered
- error checking: non-ecc
- type: 288-pin udimm
- spd speed: 2133 mhz
- spd voltage: 1.2v
- features: intel xmp 2.0(extreme memory profile)ready
- warranty: lifetime
was [£149.99] inc. vat
only £139.99 inc vat.
order now
adata xpg z1 32gb (4x8gb) ddr4 pc4-19200c16 2400mhz quad channel kit (ax4u2400w8g16-qrz) @ £239.99 inc vat
specification:-
- capacity: 32gb (8gbx4)
- spd voltage: 1.2v
was [£289.99] inc. vat
only £239.99 inc vat.
order now
asus geforce gtx 970 directcu ii oc strix 4096mb gddr5 pci-express graphics card @ £289.99 inc vat
the new nvidia geforce gtx 980/970 is powered by the next generation nvidia maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
maxwell is the most advanced gpu architecture ever made, designed to be the engine of next generation gaming. inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. for the first time, gaming gpu's can dynamically render indirect light using the new vxgi (voxel global illumination technology). scenes are significantly more lifelike as light interacts more realistically in the game environment.
the gtx 980 is the worlds fastest gpu and the gtx 970 offers the most advanced performance in its class. each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
enable the detail of 4k monitors, on a 1080p display. dsr produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
geforce gtx 980 and 970 cards support tear-free, super-fast nvidia g-sync monitor display technology including 4k. together, these technologies provide the most immersive and competitive gaming experiences possible.
features:-
- voxel global illumination technology (vxgi)
- nvidia® super resolution technology
- nvidia® gameworks technology
- nvidia® gamestream technology
- nvidia® txaa technology
- nvidia gpu boost 2.0
- nvidia physx® technology
- nvidia fxaa technology
- nvidia adaptive vertical sync
- nvidia surround
- support for four concurrent displays including: two dual-link dvi, hdmi and displayport 1.2
- microsoft directx 12
- nvidia® 3d vision® ready
- nvidia sli® ready technology
- nvidia cuda® technology
- pci express 3.0 support
- opengl 4.4 support
- opencl support
- nvidia shield ready
- nvidia g-sync ready
specification:-
- geforce gtx 970
- gpu: geforce gtx 970 (gm204)
- core base clock: 1114mhz
- core boost clock: 1253mhz
- memory clock: 7010mhz
- memory size: 4096mb gddr5
- bus type: pci express 3.0
- memory bus: 256-bit
- cuda cores: 1664
- directx 12: yes
- dvi port: 2x dual-link dvi, 1x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 1x 8-pin
- 450w psu required
- 225w tdp
- warranty: 3yr
was [£299.99] inc. vat
only £289.99 inc vat.
order now
asus geforce gtx 980 directcu ii oc strix 4096mb gddr5 pci-express graphics card @ £469.99 inc vat
features:-
- nvidia surround
- opencl support
specification:-
- geforce gtx 980
- gpu: geforce gtx 980 (gm204)
- core base clock: 1178mhz
- core boost clock: 1279mhz
- cuda cores: 2048
- directx 12: yes
- dvi port: 1x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x -pin
- 500w psu required
- 178w tdp
- warranty: 3yr
was [£499.99] inc. vat
only £469.99 inc vat.
order now
corsair vengeance 16gb (4x4gb) ddr4 pc4-23000c16 2800mhz quad channel kit - blue (cmk16gx4m4a2800c16b) @ £149.99 inc vat
vengeance lpx memory is designed for high-performance overclocking. the heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer pcb helps manage heat and provides superior overclocking headroom. each ic is individually screened for performance potential.
the ddr4 form factor is optimized for the latest intel x99 series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than ddr3 modules. vengeance lpx ddr4 modules are compatibility-tested across x99 series motherboards for reliably fast performance. there’s xmp 2.0 support for trouble-free automatic overclocking. and, they’re available in multiple colors to match your motherboard, your components, or just your style.
specification:-
- 2800mhz (pc4-23000)
- cas timings: 16-18-18-36
- voltage: 1.20v
was [£199.99] inc. vat
only £149.99 inc vat.
order now
corsair vengeance 16gb (4x4gb) ddr4 pc4-24000c15 3000mhz quad channel kit - black (cmk16gx4m4b3000c15) @ £158.99 inc vat
specification:-
- 3000mhz (pc4-24000)
- cas timings: 15-17-17-35
- voltage: 1.25-1.35v
only £158.99 inc vat.
order now
crucial bx100 120gb ssd sata 6gbps 7mm solid state drive (ct120bx100ssd1) @ £49.99 inc vat
nonl2br
<p>boot up almost instantly. load programs in seconds. and accelerate demanding applications with ease. it all starts with ditching your hard drive.</p>
<p>the storage revolution that started in 2008 with our first ssd continues with the new crucial® bx100. engineered to outperform a hard drive and deliver cost-effective performance, the crucial bx100 leverages advanced flash memory technology and moves your computer beyond the outdated storage limitations of spinning discs. by transmitting data in a digital manner rather than having to seek it out on a spinning platter, the crucial bx100 makes nearly everything on your computer faster and more efficient.</p>
<b>over 15x faster than a typical hard drive</b>
<p>get more done in less time – or just have more fun. the crucial bx100 ssd is over 15 times faster than a typical hard drive and delivers true 535 mb/s sequential reads on both compressible and incompressible data. by treating all data the same, the crucial bx100 allows you to do everything quickly, regardless of whether you’re saving an image, accessing a zip file, or loading a video.</p>
<b>over 2x more reliable than a typical hard drive</b>
<p>protect your data by storing it on the crucial bx100, which is significantly more reliable than a typical hard drive. in the computer industry, storage drive reliability is measured in mean times between failures (mtbf). most hard drives have mtbf ratings of 0.6 million hours, whereas the crucial bx100 has a reliability rating of 1.5 million hours. in practical terms, the more reliable your drive is, the less likely it is to crash.</p>
<b>nearly 2x more energy efficient than a typical hard drive</b>
<p>run your system longer and harder – using less power. with extreme energy efficiency technology, the crucial bx100 is over 90% more energy efficient than a typical hard drive. since ssds access data digitally rather than seeking it out on a spinning platter, they consume significantly less power.</p>
<b>better value than a typical ssd</b>
<p>get more out of your system – without compromising quality. at speeds up to 535 mb/s, the crucial bx100 ssd isn’t the fastest drive on the market, but that’s squarely our intent. we painstakingly engineered the crucial bx100 to provide a massive performance boost, while also delivering an unrivaled value among ssds. make the switch to the crucial bx100 and get everything you expect from a crucial ssd at an unexpected value.</p>
<b>specifications:</b>
<ul>
<li>sequential read mb/s: 535
<li>sequential write mb/s: 185
<li>random read iops: 87k
<li>random write iops: 43k
</ul>
was [£52.99] inc. vat
only £49.99 inc vat.
order now
crucial bx100 250gb ssd sata 6gbps 7mm solid state drive (ct250bx100ssd1) @ £74.99 inc vat
nonl2br
<ul>
<li>sequential write mb/s: 370
<li>random write iops: 70k
</ul>
only £74.99 inc vat.
order now
crucial bx100 500gb ssd sata 6gbps 7mm solid state drive (ct500bx100ssd1) @ £145.99 inc vat
nonl2br
<ul>
<li>sequential write mb/s: 450
<li>random read iops: 90k
</ul>
only £145.99 inc vat.
order now
samsung 120gb 850 evo ssd 2.5" sata 6gbps 32 layer 3d v-nand solid state drive (mz-75e120b/eu @ £49.99 inc vat
nonl2br
<b>specifications</b>
<ul>
<li>controller: samsung mgx controller
<li>dram cache memory: 256mb
<li>sequential read: 540mbps
<li>sequential write: 520mbps
<li>4kb random read (qd1): max 10,000 iops
<li>4kb random write (qd1): max 40,000 iops
<li>4kb random read (qd32): max 94,000 iops
<li>4kb random read (qd32): max 88,000 iops
<li>reliability: mtbf: 1.5 million hours
<li>warranty: 5 years
<li>tbw: 75tbw
<li>data security: aes 256-bit full disk encryption (fde) / tcg/opal v2.0 encrypted drive (ieee1667)
</ul>
<b>3d v-nand technology and the samsung ssd 850 evo</b>
<p>samsung’s unique and innovative 3d v-nand flash memory architecture is a breakthrough in
overcoming the density limitations, performance and endurance of today’s conventional planar nand architecture. 3d vnand is fabricated by stacking 32 cell layers vertically over one another rather than
decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in
higher density and better performance utilizing a smaller footprint.</p>
<p>the 850 evo is the advanced consumer ssd powered by 3d v-nand technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.</p>
<b>optimized performance for everyday computing experiences</b>
<p>powered by samsung's cutting-edge 3d v-nand technology, 850 evo delivers top-class sequential
and random read and write performance to optimize everyday computing. with improved performance thanks to turbowrite technology the 850 evo provides not only more than a 10% better user experience than 840 evo but up to 1.9x faster random write speeds for the 120/250 gb models as well. in fact, the 850 evo delivers top class sequential read (540 mb/s) and write (520 mb/s) performance in all capacities. this comes with optimized random read and write performance on all qd and improved qd1 and qd2 random performance for client pc usage.</p>
<b>reinforcement of turbowrite technology</b>
<p>in the early stages of the 840 evo, samsung adopted sequential write performance first. with
turbowrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the ssd. if a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit turbowrite and be processed at ”after turbowrite” speeds. once the buffer is cleared, turbowrite performance will resume. however, the buffer size for turbowrite is more than sufficient for everyday pc use, and you should experience accelerated speeds for most workloads. </p>
<p>for the 850 evo, enhanced turbowrite technology applied to random write speeds up to 1.9x faster for the 120 gb model and 1.25x faster for the 250gb model over the 840 evo.</p>
<b>guaranteed endurance and reliability for maximum use</b>
<b>guaranteed endurance</b>
<p>the 850 evo delivers guaranteed endurance and reliability by doubling the tbw compared to the
previous generation 840 evo backed by an industry leading 5 year warranty. with twice the endurance of a typical nand flash ssd, the 850 evo will keep working as long as you do. the 850 evo guarantees a 5 year limited warranty or 75tbw for 120gb and 250gb, 150tbw for 500gb and 1tb.</p>
<b>enhanced reliability with improved sustained performance</b>
<p>with enhanced reliability through improved sustained performance, the 850 evo assures longterm
dependable performance up to 30% longer than the 840 evo with minimized performance degradation. this means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.</p>
<b>advanced data encryption</b>
<p>the 850 evo provides the same data encryption feature as the 840 evo does. self-encrypting drive
(sed) security technology will help keep data safe at all times. it includes an aes 256-bit hardwarebased
encryption engine to ensure that your personal files remain secure. being hardwarebased, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. also, 850 evo is compliant with advanced security management solutions (tcg opal and ieee 1667). magician will guide ”how to use security features”. furthermore, you can erase or initialize data with the crypto erase service with psid.</p>
<b>efficient power management for all pc applications</b>
<p>power consumption affects everyone. you actually save of up to 50% more on power than
with the 840 evo during write operations thanks to 3d v-nand consuming half the power of 2d
planar nand. </p>
<p>plus, whether it’s preserving battery life for longer cordless use or just saving on costs, power
management is important. device sleep signals the ssd to enter a low power state which is vital for
ultra-books and other battery powered devices. with 850 evo’s device sleep at a highly efficient
2mw you get longer battery life on your notebook thanks to a controller optimized for 3d v-nand.
with the 850 evo you can work and play longer without having to plug in.</p>
<b>summary</b>
<ul>
<li>sata 6gb/s ssd for client pcs
<li>2.5 inch form factor
<li>samsung 32 layer 3d v-nand
<li>samsung magician software for ssd management
<li>samsung data migration software
</ul>
was [£59.99] inc. vat
order now
samsung 250gb 850 evo ssd 2.5" sata 6gbps 32 layer 3d v-nand solid state drive (mz-75e250b/eu) @ £79.99 inc vat
nonl2br
<ul>
<li>dram cache memory: 512mb
<li>4kb random read (qd32): max 97,000 iops
<li>tbw: 75tbw
</ul>
planar nand. </p>
<b>summary</b>
<ul>
</ul>
was [£89.99] inc. vat
only £79.99 inc vat.
order now
samsung 500gb 850 evo ssd 2.5" sata 6gbps 32 layer 3d v-nand solid state drive (mz-75e500b/eu) @ £149.99 inc vat
nonl2br
<ul>
<li>4kb random read (qd32): max 98,000 iops
<li>4kb random read (qd32): max 90,000 iops
<li>tbw: 150tbw
</ul>
planar nand. </p>
<b>summary</b>
<ul>
</ul>
was [£155.99] inc. vat
order now
samsung 1.0tb 850 evo ssd 2.5" sata 6gbps 32 layer 3d v-nand solid state drive (mz-75e1t0b/eu) @ £284.99 inc vat
nonl2br
<ul>
<li>controller: samsung mex controller
<li>dram cache memory: 1gb
<li>tbw: 150tbw
</ul>
planar nand. </p>
<b>summary</b>
<ul>
</ul>
only £284.99 inc vat.
order now
samsung sm951 128gb m.2 pci-e gen3 8gbps x 4 solid state drive (mzhpv128hdgm-00000) @ £79.99 inc vat
nonl2br
<p>the sm951 boasts outstanding performance, supporting both pcie 3.0 and pcie 2.0 interfaces. they can read and write sequentially at 1,600 mb/s (megabytes per second) and 1,350 mb/s respectively based on pcie 2.0. this performance level is approximately three times faster than that of the latest ssd with a sata interface and about 30 percent faster than that of the samsung xp941, its predecessor. in addition, the new ssd's random read and write speeds reach up to 130,000 and 85,000 iops (inputs / outputs per second) respectively.</p>
<p>for ultra-slim notebooks and workstations wanting to adopt the pcie 3.0 interface, the sm951 can read and write sequentially at 2,150 mb/s and 1,550 mb/s respectively, which would provide approximately four times faster sequential reading performance compared to current sata ssds. with a pcie 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 mb/s per watt for sequential reading and 250 mb/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the xp941 ssd.</p>
<p>in addition, the sm951 is the first ssd to adopt the l1.2 low power standby mode (which allows all high-speed circuits to be turned off when a pc is sleeping or in hibernation) as defined by pci-sig (the pcie standards body). by embracing the l1.2 level of standby operation, the sm951's power consumption is drastically reduced – to under 2mw, about a 97 percent decrease from the 50mw consumed using a l1 state.</p>
<p>samsung's sm951 comes in the m.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" ssd. also, it weighs approximately six grammes. the drive's compactness is well suited for most notebook pc designs, freeing up space for other components including the battery. the sm951 lineup consists of 512, 256 and 128 gb ssds.</p>
<p><b>please note.</b> some m.2 motherboards only support sata 6gbps speeds or pci-e x 2 lanes. you need to make sure your board supports pci-e x4 lanes to get the full speed from this ssd.</p>
<br>
<br>
<b>specification</b><br>
- m.2 pci-e 3.0 (x4) interface or m.2 pci-e motherboard slot<br>
- mlc nand<br>
- read speed: 2000mb/s<br>
- write speed: 600mb/s<br>
- iops: 140k/40k<br>
- warranty: 2yr<br>
order now
samsung sm951 256gb m.2 pci-e gen3 8gbps x 4 solid state drive (mzhpv256hdgl-00000) @ £129.95 inc vat
nonl2br
<br>
<br>
- mlc nand<br>
- read speed: 2150mb/s<br>
- write speed: 1200mb/s<br>
- iops: 140k/80k<br>
- warranty: 2yr<br>
only £129.95 inc vat.
order now
samsung sm951 512gb m.2 pci-e gen3 8gbps x 4 solid state drive (mzhpv512hdgl-00000) @ £249.95 inc vat
nonl2br
<br>
<br>
- mlc nand<br>
- write speed: 1500mb/s<br>
- iops: 140k/85k<br>
- warranty: 2yr<br>
only £249.95 inc vat.
order now
g.skill ripjaws 4 16gb (4x4gb) ddr4 pc4-24000c15 3000mhz quad channel kit - red (f4-3000c15q-16grr) @ £179.99 inc vat
g.skill ripjaws 4 perform in g.skill typically fashion, crazy fast! based on hynix ic the g.skill modules come recommended by 8 pack himself as they have great overclocking ability and the price is always very competitive in market.
overclockers uk is first with the g.skill range and ripjaw 4 is designed specifically for the latest x99 platform and designed to run in quad channel mode for maximum bandwidth and performance.
specification:-
- tested speed: ddr4-3000 mhz (pc4-24000)
- tested latency: 15-15-15-35
- tested voltage: 1.35v
- spd voltage: 1.2v
- seal of approval by 8 pack!!
only £179.99 inc vat.
order now
g.skill ripjaws 4 16gb (4x4gb) ddr4 pc4-25600c16 3200mhz quad channel kit - black (f4-3200c16q-16grkd) @ £239.99 inc vat
specification:-
- tested speed: ddr4-3200 mhz (pc4-25600)
- tested latency: 16-16-16-36
- spd voltage: 1.2v
order now
gigabyte geforce gtx 980 g1 gaming 4096mb gddr5 pci-express graphics card @ £449.99 inc vat
gigabyte windforce 3x 600w cooling system once again break the record and bring the air cooling capacity up to 600w by only using 2 slots heights. the windforce 3x 600w cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and gigabyte “triangle cool” technology. this not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
gigabyte flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. users could enjoy the best gaming experience in ultra hd resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
with gpu gauntlet™ sorting, the gigabyte soc graphics card guarantees the higher overclocking capability in terms of excellent power switching. ultra durable vga board provides dramatic cooling effect on lowering both gpu and memory temperature by doubling the copper inner layer of pcb. ultra durable vga board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. ultra durable vga board allows more bandwidth for electron passage and reduces circuit impedance. the less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
features:-
- windforce 3x 600w cooling system
- flex display technology(patent-pending)
- powered by nvidia geforce gtx 980 gpu
- integrated with industry's best 4gb gddr5 memory 256-bit memory interface
- features dual-link dvi-i / dvi-d / hdmi / displayport*3
- base: 1228 mhz / boost: 1329 mhz
- system power supply requirement: 600w(with two 8-pin external power connectors)
- nvidia surround
- opencl support
specification:-
- geforce gtx 980
- core base clock: 1228mhz
- core boost clock: 1329mhz
- cuda cores: 2048
- directx 12: yes
- dvi port: 1x dual-link dvi, 1x dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- dimensions: l=312mm, w=129mm, h=43mm
- power: 2x 8-pin
- 600w psu required
- 220w tdp
- warranty: 3yr
- bit-tech review: http://www.bit-tech.net/hardware/graphics/2014/10/02/gigabyte-geforce-gtx-980-g1-gaming-review/1
was [£509.99] inc. vat
only £449.99 inc vat.
order now
gigabyte geforce gtx 970 g1 gaming 4096mb gddr5 pci-express graphics card @ £289.99 inc vat
features:-
- windforce 3x cooling system
- powered by nvidia geforce gtx 970 gpu
- base: 1178 mhz / boost: 1329 mhz
- system power supply requirement: 550w (with one 6-pin and one 8-pin external power connectors)
- nvidia surround
- opencl support
- flex connectivity (upto 6 monitors)
specification:-
- geforce gtx 970
- cuda cores: 1664
- directx 12: yes
- dvi port: 2x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 1x 8-pin & 1x 6-pin
- 450w psu required
- 150w tdp
- warranty: 3yr
order now
gigabyte geforce gtx 970 windforce oc 4096mb gddr5 pci-express graphics card (gv-n970wf3oc-4gd) @ £269.99 inc vat
features:-
- nvidia surround
- opencl support
specification:-
- geforce gtx 970
- cuda cores: 1664
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- 450w psu required
- 150w tdp
- warranty: 3yr
only £269.99 inc vat.
order now
gigabyte geforce gtx 970 "mini-itx" 4096mb gddr5 pci-express graphics card (gv-n970ixoc-4gd) @ £259.99 inc vat
measuring merely 17cm in length, the card, specially built for small form factor pcs based on mini-itx motherboards. packed with gigabyte’s unique blade fan design, pure copper heat pipes and patented ‘triangle cool’ technology, delivering superior cooling capacity at an extremely low noise level given its compact size.
the air flow is split through the triangle design at the fan edge, and is guided smoothly through the fan by the special 3d stripe curve design, effectively enhancing the air flow by 23% over traditional fans, whilst reducing air turbulence.
“triangle cool” fan-sink integrates a patented triangle-shaped aluminum block into the aluminum extrusion module. the triangle design not only minimizes the turbulence between extruded aluminum fins, but also enhances heat dissipation to improve cooling efficiency for the whole fan-sink.
features:-
- powered by nvidia geforce gtx 970, the latest maxwell architecture
- suitable for small form factor pcs and mini-itx motherboards
- 17cm length design with unique blade fan and patented “triangle cool” technology
- 26.8 db in 3d gaming (14db lower than reference in 3d gaming)
- gigabyte dual bios technology
- ultra durable graphics card components.
- oc guru ii with gpu boost 2.0 technology
specification:-
- geforce gtx 970
- core base clock: 1076mhz
- core boost clock: 1216mhz
- cuda cores: 1664
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 1x 8-pin
- 450w psu required
- 145w tdp
- warranty: 3yr
was [£269.99] inc. vat
only £259.99 inc vat.
order now
intel core i7-4790k 4.00ghz (devil's canyon) socket lga1150 processor - retail @ £251.99 inc vat
want to tune every aspect of your system for the ultimate in total system control. then the new unlocked intel core processors which enable system tuning for the processor cores, memory, graphics, and power, were made for you. whether you are a novice overclocker or a seasoned veteran, these processors will have you singing their praises in no time.
looking for the perfect processor to build your gaming rig around? but you also want to edit your action videos and photos? but to do this you know you need serious performance. not to worry - intel is happy to announce our first 4ghz base frequency quad core processor. if it is performance you crave, then this is the processor you have been waiting for. but what if you feel the need to overclock your system to squeeze every last bit of performance out of it? well, then this is still the perfect processor you. the lastest 4th gen intel core i5 and intel core i7 processors, paired with the latest intel 9 series h and z chipsets, will get you the results you want. add in features like built in visuals and intel quick sync video, which allows the conversion of media from one device to another and prepares your media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
the intel core processor family delivers a great pc experience. whether you are looking for improved performance, greater adaptability, or differentiated visual features, intel has the processor to fit your needs. whether you use your pc for creativity, playing games, or everyday task such as homeworkd and email, these new processors make it easier to design, render, edit, play, and share.
intel core and for intel core i7 processors, intel hype-threading technology allows each processor core to work on two task at the same time, improving multitasking, speeding up the workflow, and accomplishing more in less time.
with 4th gen intel core processors, you can boot your pc, load applications, and resume from sleep nearly instantaneously thanks to intel's responsiveness technologies such as intel smart response technology and intel rapid start technology.
the 4th gen intel core processor family offers hardware-level security that helps protect your devices, your data, and your online transactions.
the 4th gen intel core processor family automatically connects to wireless hotspots. your email, social media, and apps are always updated thanks to intel smart connect technology. finally, wirelessly stream your hd / 3d video and games to your tv or projector for presentations and entertainment using intel wireless display technology.
features:-
- improved thermal interface material (tim)
- updated packaging materials
- supported by new intel 9 series chipset
- re-engineered for enhanced performance & overclocking
specification:-
- lithography process: 22 nm
- cores: 4
- threads: 8
- frequency: 4.00 ghz (turbo mode 4.40ghz)
- integrated hd 4600 graphics
- cache: 8 mb shared l3
- memory controller: dual channel ddr3 1600/1866/2133/2400/2666+ mhz
- socket: lga1150
- memory compatibility: all ddr3 1333mhz and above is compatible
- psu compatibility: check out our range of haswell compatible psu's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr warranty
only £251.99 inc vat - with £300 worth of free software!!
order now
intel core i5-4690k 3.50ghz (devil's canyon) socket lga1150 processor - retail @ £179.99 inc vat
features:-
specification:-
- cores: 4
- threads: 4
- frequency: 3.50 ghz (turbo mode 3.90ghz)
- cache: 6mb shared l3
- socket: lga1150
- 3yr warranty
only £179.99 inc vat - with £150 worth of free software!!
order now
intel 5820k 3.30ghz (haswell-e) socket lga2011-v3 processor - oem (cm8064801548435) @ £299.99 inc vat
intel's latest haswell-e 2011-v3 processors is the most powerful desktop gaming processor you can get, perfect for gamers, video encoders and professional audio. with a whopping 6 cores which means 12 threads with hyperthreading technology the power on tap is unlimited. the 5820k is also intel's lowest ever priced 6 core, 12 threaded cpu ever, making such power more affordable.
as always overclockers uk have done some overclock testing and the results are very impressive with speeds of over 4.5ghz being achieved which for an 6/12 processor is very impressive. we are recommending custom water-cooling loops for people wanting to overclock beyond 4ghz to keep things cool and ocuk has the largest range of in stock ddr4 memory from avexir, crucial, corsair and g.skill.
features:-
- 22nm tri-gate 3d transistors
- 6 cores, 12 threads
- 15mb of intel smart cache
- intel turbo boost technology
- conflict-free microprocessor
- distribution of ai, physics and rendering across multiple threads delivers intense gaming exerience
- faster video encode, image rendering, audio production, and real-time preview
- overclocking-enabled for extra performance
- new intel x99 chipset delivers enhanced i/o
- 4 channel ddr4 upto 4266mhz support
specification:-
- only compatible with x99 motherboards & ddr4 memory!
- 3.30ghz base frequency
- 3.60ghz turbo frequency
- fully unlocked
- 15mb cache
- intel turbo boost technology 2.0
- intel hyper-threading technology
- supports lga 2011-v3 socket
- 28 pci express 3.0 lanes
- transistor count: 2.6 billion
- die size: 17.6mm x 20.2mm
- tdp: 140w
- thunderbolt 2 capable
- bclk overclock support from chipset
- warranty: 1yr
was [£319.99] inc. vat
only £299.99 inc vat - with £300 worth of free software!
order now
intel 5820k 3.30ghz (haswell-e) socket lga2011-v3 processor - retail (bx80648i75820k) @ £305.99 inc vat
features:-
specification:-
- fully unlocked
- 15mb cache
- tdp: 140w
- warranty: 3yr
was [£329.99] inc. vat
only £305.99 inc vat - with £300 worth of free software!!!
order now
intel 5930k 3.50ghz (haswell-e) socket lga2011-v3 processor - retail (bx80648i75930k) @ £439.99 inc vat
features:-
specification:-
- 3.50ghz base frequency
- 3.70ghz turbo frequency
- fully unlocked
- 15mb cache
- 40 pci express 3.0 lanes
- tdp: 140w
- warranty: 3yr
only £439.99 inc vat - with £300 worth of free software!!
order now
kfa2 geforce gtx 980 soc gamer 4096mb gddr5 pci-express graphics card (98nqh6dnc7vz) @ £409.99 inc vat
features:-
- nvidia surround
- opencl support
specification:-
- advanced ir3595 digital pwm
- multi-layer ceramic capacitors (helps reduce coil whine)
- geforce gtx 980
- process: 28nm
- cuda cores: 2048
- directx 12: yes
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 500w psu required
- 165w tdp
- review 1: http://www.guru3d.com/articles-pages/galax-geforce-gtx-980-soc-review,1.html
- Review 2: http://hexus.net/tech/reviews/graphics/76361-galax-geforce-gtx-980-soc/
- Warranty: 2yr
Was [£455.99] Inc. VAT
Only £409.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 970 OC Silent "Infin8 Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £289.99 inc VAT
Since Overclockers UK introduced our Infin8 system range, demand for high performance zero compromise systems has exploded. Our Infin8 brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Was [£319.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 970 EX OC "Black Edition" 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4TX) @ £269.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1164MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Review: http://www.overclock3d.net/reviews/gpu_displays/galax_gtx970_ex_oc_black_edition_review/20
- Warranty: 2yr
Was [£289.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £119.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
TeamGroup Elite 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD432GM2400HC16QC01) @ £259.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
ASUS ROG G501JW-FI201H - 15.6" 4k LED / i7-4720HQ / Nvidia GTX 960M 4G / 8G / 512GB PCI-E M2 SSD / Win 8.1 64B **OcUK Exclusive LIMITED EDITION** @ £1,699.99 inc VAT
OcUK has made a deal with Asus for their highest most premium built laptop yet, the G501JW chassis is constructed completely from aluminum and not plastic, for ultimate in feel and quality. Then the specification is absolutely mind blowing, featuring a yet to be released NVIDIA GPU (March 12th) and an incredible QFHD 4k LED display making this a truly portable laptop for both gamers, professionals and photographers.
The is a limited product of this chassis/specification and exclusive to OcUK. We will only ever get one delivery of 168pc, so this will be a rare beast so now is your chance to have one of the most stunning laptops on the market. We expect our stock to arrive after April but due to limited numbers we are making this available for pre-order now and will remove the product from sale once the 168pc allocation is sold out.
Specification:
- Part No: 90NB0873-M01230
- Model Name: G501JW-FI053H
- LCD Cover Color & Decoration: Aluminum, Black vertical hairline anodized, ROG and ASUS logo
- Top Case Color & Decoration: Aluminum, Black sand-blasting anodized
- On board processor: Intel® Core™ i7-4720HQ Processor, 2.6 GHz (6M Cache, up to 3.6 GHz)
- Operating System: Windows 8.1 (64bit)
- Office: Microsoft® Office 2013 Trial
- Chipset: Mobile Intel® HM87 Express Chipsets
- Memory Slot: 1x
- On board memory: 8GB
- DIMM Memory: DRAM DDR3 8G
- Total System Memory: 8GB (8GB)
- Storage: PCIEx4 512G M.2 SSD
- Display: 15.6'//LED Back-lit//Ultra Slim 300nits//QFHD 3840x2160 16:9//AG//NTSC:72%//WV
- External video display modes: "HDMI 1.4
Displayport 1.1A"
- Discrete/Share: Discrete
- Video Graphics: NVIDIA GeForce GTX960M
- IGPU: Intel HD Graphics 4600
- Video memory: GDDR5 4GB
- Video Camera: HD web camera
- Built-in TV-Tuner: N/A
- FingerPrint: N/A
- Wireless: 802.11ac+Bluetooth 4.0 (Dual band)
- LAN: 10/100 Mbps
- Card Reader: Sepc: SD/MMC
- USB Port: 3x USB 3.0
- Interface: "1x Headphone-out & Audio-in Combo Jack
1x HDMI
1x mini Display Port"
- Audio: "Built-in speaker
Built-in microphone
Built-in array microphone
Bang & Olufsen ICEpower®
Sonic Master"
- Weight (Kg): "1.78 KG (Without Battery)
2.27 KG (with 6 cell battery)"
- Dimension (cm): 38.3(W) x 25.5(D) x 2.06 ~ 2.13 (H) cm
- AC Adapter: "120W AC Adapter
Output : 19V DC, 6.3A, 120W
Input : 100~240V AC, 50/60Hz universal"
- Battery: 96WHrs, 3S2P, 6-cell Li-ion Polymer Battery Pack
- Keyboard Type: Illuminated Chiclet Keyboard
- Keyboard Specification: ASUS 348mm keyboard with 19mm full size key pitch, integrated Numeric keypad
- Antivirus and Tool Software: "Trend Micro Titanium 2013 30 day trial
Power2Go
GamePark Console
SKYPE
MyBitCast"
- Supplied Accessories: Gaming Carry bag + USB2.0 to RJ45 cable + mDP to VGA cable
Was [£1899.99] Inc. VAT
Only £1,699.99 inc VAT.
ORDER NOW
ASUS ROG G751JT-T7070H - 17.3" FHD IPS LED / i7-4710HQ / Nvidia GTX970M 3G / 16G / 1TB 7200 + 128G SSD / BD Read / Win 8.1 64B @ £1,199.99 inc VAT
nonl2br
<br>
<br>
The unbeatable gaming laptop with TurboMaster overclocking
G751 is an unbeatable gaming laptop thanks to its 4th-gen Intel® Core™ i7 processor and NVIDIA® GeForce® GTX graphics, with TurboMaster technology for stable GPU overclocking and ROG AudioWizard-enhanced audio for immersive gaming. Its intelligent dual-fan cooling system keeps everything cool even in the heat of battle, and special keys let you access Steam or share memorable gaming moments with the world!
<h1>Designed to get you in the game</h1>
<p>With its aluminum finish and illuminated ROG logo, there's no doubting the ROG G751's gaming DNA. You'll be immersed in a Full HD gaming world through a 178-degree wide-view angle display with an anti-glare coat; while an ergonomically-angled keyboard ensures no fatigue during marathon gaming sessions. There's even special Game Keys for Steam, gameplay recording, and macros
<h1>Stealth fighter-inspired aluminum chassis</h1>
<p>ROG G751 retains the classic stealthy F-22 Raptor-inspired lines found on previous G Series iterations; only this time it sports an aluminum finish with an illuminated ROG logo. Dual rear vents add to the visual drama, and play a part in its highly efficient and effective thermal design.</p>
<h1>Ergonomically-angled keyboard</h1>
<p>ROG G751 has an ergonomically-angled keyboard and a durable, soft touch, anti-slip palm rest to ensure your hands and wrists stay comfortable even during marathon gaming sessions.</p>
<h1>Programmable game keys and marked WASD keys</h1>
<p>ROG G751 has dedicated keys for instant Steam access and one-click gameplay recording. The ASUS ROG Macro Key can be programmed with up to three commands, so you can make complex in-game multi-key actions, launch applications, or load up a specific website with one keystroke. It also features specially-marked WASD keys.
<h1>Responsive backlit keyboard</h1>
<p>The seamless one-piece keyboard has 2.5mm of key travel to give you responsive keystrokes and no key float for a solid typing feel. Isolated arrow keys provide a true gaming feel, while the large multi-touch touchpad with scissor feet buttons enable easy navigation. Keyboard backlight levels are adjustable for low-light environments.</p>
<h1>Spectacular Full HD IPS display</h1>
<p>The Full HD IPS display gives you 178-degree wide viewing angles for minimal colour shift even when you view it from extreme angles. You get to enjoy spectacular visuals and color accuracy, and even share your favorite gaming moments with family and friends by your side. A matte anti-glare coat gets rid of annoying reflections so you can focus on what's onscreen without straining your eyes.</p>
<h1>Awesome gaming performance</h1>
<p>The quad-core Intel<sup>®</sup> i7 processor gives you the gaming performance you need without sacrificing efficiency, while gaming-grade NVIDIA<sup>®</sup> GeForce<sup>®</sup> GTX graphics satisfies the most hardcore gamer's need for supreme visuals. ASUS TurboMaster Technology provides simple and stable real-time GPU overclocking; while an intelligent dual-fan cooling system ensures ROG G751 withstands the demands of high performance gaming.
<h1>Powerful Intel<sup>®</sup> Core™ processor</h1>
<p>The 4<sup>th</sup> gen Intel<sup>®</sup> Core™ i7 processor found in the ROG G751 provides efficient, powerful performance for the demands of today's fast-paced games and multitasking.</p>
<h1>Enthusiast-grade NVIDIA<sup>®</sup> GTX series graphics</h1>
<p>The latest enthusiast-grade NVIDIA<sup>®</sup> GTX series graphics scores over 9.3K in the 3DMark 11 performance benchmark, providing you with sharper visuals for fast-paced games. NVIDIA<sup>®</sup> GeForce<sup>®</sup> Experience™ optimizes settings for higher resolutions and greater in-game detail for extra-sharp image quality; it also enhances frame rates to give you super smooth gameplay.</p>
<h1>ASUS TurboMaster for a graphics boost</h1>
<p>ASUS TurboMaster technology, gives you the ultimate gaming experience. ASUS TurboMaster supports real-time GPU overclocking to give you a performance boost of over 5%. An upgraded PCB design ensures a stable power supply; and features a dedicated 3-phase GPU power design along with upgraded Tantalum capacitors. </p>
<h1>Intelligent dual-fan cooling system for stable performance</h1>
<p>Hyper Cool with Duo-copper heat sinks and independent rear-vented dual fans guarantee system stability even when overclocking. The CPU and GPU get their own dedicated fans; with three heat pipes drawing heat to the GPU fan to provide efficient, silent cooling. The hot exhaust is also directed away from you through the rear vents.</p>
<h1>Geared for incredible gaming experiences</h1>
<p>Intel<sup>®</sup> Thunderbolt™ technology provides ultra-fast graphics and data transmission via a single connection; while GameFirst III optimizes networks to give you smooth, lag-free online gameplay. ROG G751 has a Full HD IPS display that gives you incredible levels of detail. It also has ASUS Trinity Display technology so you can hook the ROG G751 to up to three displays for multi-display gaming set-ups.</p>
<h1>Faster connections with Thunderbolt™ technology</h1>
<p>Intel<sup>®</sup> Thunderbolt™ technology gives you ultra-fast graphics and data transmission via a single connection. This new standard has the capacity to deliver data and graphics at up to 20Gbit/s - almost double the bandwidth of USB 3.0. Dual protocols provide more connectivity options, allowing you to turn ROG G751 into a hub for your various devices.</p>
<h1>Multi-task with Trinity Display</h1>
<p>Trinity Display technology allows ROG G751 to output to three displays simultaneously through its HDMI 1.4 and mini DisplayPort 1.2 ports. Gaming aside, Trinity Display is ideal for movies as well as multi-tasking. </p>
<h1>Realistic, immersive<br>in-game audio</h1>
<p>SonicMaster completely immerses you in high quality in-game audio, with MaxxAudio, a professional-grade processing tool, and ROG Audio Wizard giving you several preset audio modes suited for different gaming genres for total mastery over in-game sounds.<br>ROG G751 also includes Bass Eye - an internal subwoofer that's perfectly balanced with the rest of the notebook for added low-frequency impact.</p>
<h1>SonicMaster Audio</h1>
<p>A mixture of hardware, software, and tuning, SonicMaster was developed by the ASUS Golden Ear team with the clear goal of giving you the best notebook PC audio. Larger speakers and resonance chambers deliver powerful sound and deeper bass; while specialized software tailors audio for a wide range of entertainment. Whether you're listening on headphones or speakers, SonicMaster delivers richer, more detailed sound.</p>
<br>
<Br>
<br>
Specification:<br>
- LCD Cover Color & Decoration: Black<br>
- Top Case Color & Decoration: Black<br>
- On board processor: Intel® Core™ i7-4710HQ Processor, 2.5 GHz (6M Cache, up to 3.5 GHz)<br>
- Operating System: Windows 8.1 (64bit)<br>
- Office: Microsoft® Office 2013 Trial<br>
- Chipset: Mobile Intel® HM87 Express Chipsets<br>
- Memory Slot: 4x<br>
- DIMM Memory: DRAM DDR3 8G *2<br>
- Total System Memory: DRAM DDR3 8G *2<br>
- Storage: SATA 1TB 7200RPM 2.5' HDD, SATA 128G 2.5' SSD<br>
- Display: 17.3'//LED Back-lit//300nits//FHD 1920x1080 16:9//AG//NTSC:72%//EWV<br>
VGA max. 2048*1536 @85Hz refresh rate
Displayport 1.1A"
- Discrete/Share: Discrete<br>
- Video Graphics: NVIDIA GeForce GTX970M (N16E-GT)<br>
- Video memory: GDDR5 3GB<br>
- Video Camera: HD web camera<br>
- Optical Drive: [SATA] 9.5"mm 6X Blu-Ray (Read)<br>
- Built-in TV-Tuner: N/A<br>
- FingerPrint: N/A<br>
- Wireless: 802.11ac+Bluetooth 4.0 (Dual band) -WIDI<br>
- 3G/4G: N/A<br>
- LAN: 10/100 Mbps<br>
- Card Reader: SD?MMC<br>
- USB Port: 4x USB 3.0<br>
- Interface: "1x Microphone-in jack
1x Headphone-out jack (S/PDIF)
1x RJ45 LAN Jack for LAN insert
1x VGA Port (D-Sub)
1x HDMI
1 x Thunderbolt"<br>
Built-in subwoofer
Sonic Master"<br>
- Weight (Kg): "3.60 KG (Without Battery)
3.80 KG (with 8 cell battery)"<br>
- Dimension (cm): 41.6(W) x 31.8(D) x 2.30 ~ 4.30 (H) cm<br>
- AC Adapter: "230W AC Adapter
Output : 19.5V DC, 11.8A, 230W
Input : 100~240V AC, 50/60Hz universal"<br>
- Battery: 88WHrs, 4S2P, 8 cell Li-ion Battery Pack<br>
- Keyboard Type: Illuminated Chiclet Keyboard<br>
- Keyboard Specification: ASUS 417mm keyboard with 19mm full size key pitch and integrated numeric keypad<br>
- Antivirus and Tool Software: "30 days Office 365 Home Premium
Power2Go
Adobe Reader
McAfee Internet Security 2012
MaxxAudio"<br>
- Security :"Intel Anti-theft
LoJack"<br>
- Supplied Accessories: Without carry bag<br>
- Warranty: 2yr<br>
<br>
Was [£1299.95] Inc. VAT
Only £1,199.99 inc VAT.
ORDER NOW
Acer K272HUL 27" Widescreen LED Gaming Slim Bezel Flicker FREE Monitor - Black @ £199.99 inc VAT
The 2560 x 1440 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
As part of our commitment to sustainable operations and corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Features:-
- 27" WQHD Acer ComfyView display: shows brilliant widescreen visuals
- 2560 x 1440 resolution
- Stunning colors thanks to AHVA panel (with IPS technology)
- Ergonomic stand tilts from -5 to 25 degrees
- Environmentally friendly
Specification:-
- Screen Size: 27"W, AHVA LED
- Resolution (max.): 2560 x 1440
- Brightness: 350 cd/m2
- Contrast Ratio: 1000:1
- DCR: 100M:1
- Response Time: 6 ms GTG
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: DVI-D / 2x HDMI / DisplayPort
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 5W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr (On-Site with Acer - 0371 760 1000)
Only £199.99 inc VAT.
ORDER NOW
Acer B276HULA 27" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £269.99 inc VAT
The Acer B276HULA is a high quality 27” display with WQHD resolution enabling sharper and more detailed content and true to life color accuracy for the most intense work applications and multi-tasking environments.
The B276HULA display is easy to adapt to personal needs and to integrate into any office environment, featuring a flexible height adjustment, tilt, pivot and swivel foot-stand.
The B276HULA 27’’ display provides multiple interface options, including HDMI, DisplayPort and traditional DVI, as well as 4 USB 3.0 ports with power-off charging. The perfect interface for multi-streaming or multi-application viewing.
The Acer Eco-Display technology used in the B6 series helps to minimize environmental impact and reduces the total costs of ownership (TCO).
The 2560 x 1440 resolution of this LED monitor delivers excellent detail with high pixel density, making it perfect for advanced HD productivity and specialized financial or CAD applications. View more details over a high quality large screen display with fantastic image consistency even from wide viewing angles.
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. The ergonomic design of this monitor optimizes the viewing position for maximum comfort even during prolonged use.
6 axis color adjustment feature to meet the highest standard of color accuracy. Individual Hue and Saturation of Red, Green, Blue, Cyan, Yellow and Magenta colors can be customized by users.
Increase productivity by viewing one main program on the full screen at the same time as one or more other programs are displayed on the inset windows. The intelligent Acer display can choose different audio sound source by manually.
Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of our commitment to sustainable operations and CSR, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Features:-
– Sharp details with high pixel density, view 4 X HD applications
– Exceptional color accuracy and customization with 6 axis color adjustment
– Robust Ergonomic stand: adjustable tilt, swivel, pivot and height
– Earth-friendly: recycled plastic, LED backlight, Acer EcoDisplay
– Extensive connectivity: HDMI®, DisplayPort™, DVI and USB 3.0
Specification:-
- Full Height adjust stand, pivot, swivel & tilt
- DCR: 100M:1
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Warranty: 3yr (On-Site with Acer - 0371 760 1000)
Was [£349.99] Inc. VAT
ORDER NOW
Acer 4k2k B286HK 28" Professional Widescreen LED Monitor - Black (UM.PB6EE.009) @ £329.99 inc VAT
Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
Specification:
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (71cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Colours: 16.7m
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 100,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort, 1x Mini-DP, 1x DVI and 1x HDMI
- USB 3.0 Hub
- VESA: 100x100mm
- Speakers: Yes
Was [£439.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Acer Predator 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
nonl2br
<p>
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
</p>
<p>
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
</p>
<p>
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
</p>
<p>
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
</p>
<p>
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
</p>
<p>
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
</p>
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</center>
<br><br>
<p>
<h1>Features:</h1>
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.<br>
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.<br>
- ComfyView technology – the non-glare panel reduces reflection from light source.
</p>
<p>
<h1>Specification:</h1>
- G-Sync Technology<br>
- Flicker-less Technology<br>
- Height Adjust stand with tilt, swivel and pivot<br>
- Display Screen Size: 28" (70.8cm)<br>
- Aspect ratio: 16:9<br>
- Panel Type: TN<br>
- Brightness: 300cd/m2<br>
- Contrast Ratio: 1000:1 (Typ)<br>
- Dynamic Contrast Ratio: 10,000,000<br>
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br>
- Response Time: 1ms (GTG)<br>
- Colurs: 16.7M<br>
- Bits: 8 bits+HiFRC<br>
- Viewing Angle (H / V ): 170 ° / 160 °<br>
- Connectivity: 1x DisplayPort 1.2 (60Hz)<br>
- USB Hub 3.0: Yes (1up, 4down)<br>
- VESA: 100x100mm<br>
- Speakers: No<br>
- Warranty: 2yr (Return to base with Acer - 0371 760 1000)
</p>
Was [£529.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Acer Predator XB270HU 27" G-Sync IPS 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HB0EE.009) @ £679.99 inc VAT
The Acer XB270HU not only has a IPS panel, but it can do 144Hz IPS and has G-sync support as well, is this monitor nirvana.
What makes this very interesting is that it is labelled as an IPS screen, and offers support for 144Hz refresh rate and support for NVIDIA's G-sync refresh rate technology. This is the first display featuring an IPS panel with native 144Hz refresh rate.
Offering tilt, height and swivel stand adjustments. We believe the screen to feature only a DisplayPort video connection as reported before.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 4ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (69cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- Panel: IPS
- Response Time: 4ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- G-Sync Enabled
Was [£695.99] Inc. VAT
Only £679.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £409.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- Screen Size: 32"W, VA LED
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- Warranty: 2yr (On-Site with BenQ - 0207 216 0039)
Was [£449.99] Inc. VAT
ORDER NOW
Dell UltraSharp U3415W 34" Curved Widescreen LED Monitor - Midnight Black @ £629.99 inc VAT
Discover one of the world’s first 34 inch 21:9 curved monitors with a panoramic view, cinematic WQHD resolution and superb sound.
Enter a new dimension of multitasking with a curved monitor that delivers an immersive, panoramic screen that surrounds your senses with amazingly detailed edge-to-edge WQHD (3440x1440) imagery and crystal-clear sound. More connectivity features allow you to multitask on-screen or game without interruption.
Your Dell UltraSharp 34 Curved Monitor – U3415W is designed to be pixel perfect. That’s why if you find even just one bright pixel, we’ll replace it under our Premium Panel Guarantee. Should you need help down the road, this high-performance monitor also comes with a 3-year Limited Hardware Warranty. Enjoy hassle-free convenience as you update your monitor’s firmware with the new Firmware Update Utility software.
Features:
- An immersive panoramic experience: The DellTM UltraSharp 34 inch Curved Monitor engages you in a new wrap-around viewing experience with a 21:9 ultra-wide curved screen that offers more display area and enhanced viewing comfort.
- Unrivaled usability: Navigate across multiple applications and video inputs with Picture by Picture and Picture in Picture features.
- Above and beyond reliable: Get the most from you monitor with our Premium Panel Guarantee, 3-year Limited Hardware Warranty and 3-year Advanced Exchange Service and the Firmware Update Utility Software.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1 (200,000,000:1 DCR)
- Response Time: 5ms
- Viewing Angle (CR>10): 178/172
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 1x Mini-DisplayPort
- Speakers: 2x 9W
- Weight: 8.44kg
- Warranty: 3yr (On-Site with Dell - 0844 444 4699)
Was [£679.99] Inc. VAT
Only £629.99 inc VAT.
ORDER NOW
LG 24GM77 24" TRUE 144Hz Widescreen LED Monitor - Black /w Flicker FREE Technology @ £199.99 inc VAT
For the smoothest gaming experience, MOTION 240 creates an effect similar to changing a frame 240 times and eliminates afterimages whilse minimizing motion blur. It also improves response time and delivers ultra-smooth playback by performing at a speed faster than 1ms, the speed that gamers are looking for.
A Dynamic Action Sync Mode, make real-time commands and strike fast. Gamers can catch every single moment in real-time with dynamic action sync mode. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. Make timely commands to win!
A Black Stabilizer, enhanced gamer visilbility to win in pitch black areas. Black stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Convenient game mode and game pad. Quick and easy customizable settings for your perfect gaming display environment.
Features:-
- Gaming without blurring and ghosting with "Smooth Motion"
- Detect enemies one step faster with "Swift Action"
- Personalized gaming environment with "Rapid * Easy Settings"
- Motion 240
- Dynamic Action Sync
- Black Stabilizer
Specification:-
- Height adjust and swivel stand.
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Aspect Ratio: 16:9
- Resolution (max.): 1920 × 1080
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. under 1ms (GTG)
- Brightness: 350cd/m2
- Display Colors: 16.7 million
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- Flicker-free Technology: Yes
- VESA: Yes 100x100
- Warranty: 3yr (On-Site with LG - 0344 847 5454)
Was [£209.99] Inc. VAT
ORDER NOW
Philips BDM4065UC 40" 4K 60Hz Widescreen LED Monitor - Black @ £679.99 inc VAT
See the big picture with all the details. The expansive 40" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in Ultra HD. Expand your viewing experience with the monitor that is designed for the way you work.
These latest Philips screens deliver UltraClear, 4K UHD (3840x2160) pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like DisplayPort, HDMI, Dual link DVI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets. Philips displays will give you UltraClear images.
Philips VA LED display uses an advanced vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 176/176 degree extra wide viewing angle, resulting in crisp images.
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturati on and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
Mobile High Definition Link (MHL) is a mobile audio/video interface fo r directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL capable mobile device to this large Philips MHL display, and watch your HD videos come to life with full digital sound. Now not only you can enjoy your mobile games, photos, movies, or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power half way.
Features:
- Expansive 40-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- VA display gives awesome images with wide viewing angle
- MultiView enables active dual connect and view at same time
- SmartImage presets for easy optimized image settings
- LED Technology ensures low power and natural colors
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Display Screen Size: 40"
- Panel Type: VA
- Contrast Ratio: 5000:1 (Typ)
- Dynamic Contrast Ratio: 500,000,000
- Response Time: 3ms (GTG)
- Viewing Angle (H / V ): 176 ° / 176 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB 3.0 Hub: Yes
- Speakers: Yes (2x 7W Stereo)
- VESA: 200x200mm
- Warranty: 2yr (On-Site with Philips)
Was [£799.99] Inc. VAT
ORDER NOW
Samsung S24E510C 24" Curved Widescreen LED Monitor - Black @ £199.99 inc VAT
The latest in curved monitors from Samsung!
Specification:-
- Screen Size: 24"
- Curve: 4000R
- Panel Type: VA
- Backlight: LED
- Brightness: 250cd/m
- Dynamic Contrast Ratio: 10,000,000:1
- Static Contrast Ratio: 3000:1
- Resolution: 1920x1080
- Viewing Angles: 178/178
- Colour Support: 16.7M
- Connectivity: 1x HDMI
- Stand Type: Tilt
- Warranty: 2 Years (On-Site with Samsung - 0330 726 7864)
Was [£229.99] Inc. VAT
ORDER NOW
Samsung S29E790C 29" WideScreen Super-Wide Curved LED Monitor @ £469.99 inc VAT
Specification:-
- Screen Size: 29"
- Curve: 3000R
- Panel Type: VA
- Backlight: LED
- Static Contrast Ratio: 5000:1
- Resolution: 2560x1080
- Speakers: 2x 7W
- Stand Type: Tilt
Was [£499.99] Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
Samsung S32E590C 32" WideScreen Super-Wide Curved LED Monitor @ £409.99 inc VAT
Specification:-
- Screen Size: 29"
- Curve: 3000R
- Panel Type: VA
- Backlight: LED
- Speakers: 2x 5W
- Stand Type: Tilt
Was [£429.95] Inc. VAT
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black @ £319.99 inc VAT
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
Specification:
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)
- Packaging (W x H x D ): 794x452x109 (mm)
- Panel Type: TN
- Brightness: 300cd/m2>
- Color Support : 1B
- USB Hub: NO
- Speakers: NO
- Warranty: 2yr (On-Site with Samsung - 0330 726 7864)
Was [£389.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
CHECK OUT ALL OUR THIS WEEK ONLY DEALS - CLICK HERE!
REMEMBER WITCHER 3 NVIDIA FREE GAME PROMOTION ENDS ON MONDAY 1ST JUNE!!
REMEMBER QUALIFYING INTEL PROCESSORS COME WITH LOADS OF FREE SOFTWARE!!
REMEMBER INTEL ARE RUNNING SEVERAL CASHBACK PROGRAMMES WHERE YOU CAN CLAIM UPTO £150 BACK FROM INTEL DIRECT!!
With the battering it's taken recently I'm amazed my poor wallet hasn't called it quits already because it must know what's coming after looking at those bloody silly prices! :eek:
Too late, got a Samsung SM951 :D
Can we expect SSD prices to drop further, now that RAM prices have gotten closer and closer to 2013 level? :D
RAM and NAND do not follow the same trends, they can be complete opposites at times.
SSD pricing seems pretty stable, literally the only movements in NAND recently have being due to exchange rates.
Memory prices on DDR3 now seem to be bottoming, maybe a few more quid at best.
DDR4 is still falling but at the same time OcUK is miles ahead of the market on DDR4 pricing, I mean come on 3000MHz 16GB kits for around £150 on Corsair, every competitor is around £200, were kicking ass because OcUK uses its own money to bring price even lower. :)
Was humming and harring about that LG 24" screen, think its time to retire the old trusty Samsung T220 and join the 1080p era xD
Asus Designo MX27AQ
On sale this week :D, I'll be getting this I think! its beautiful and the colors are great :O
Yeah our SSD business is seeing some excellent growth, Samsung and Crucial sales are off the chart. :)
The SSD line is probably seeing some decent growth now because your pricing is finally decent thanks to you being responsible for them. Before they were nothing to write home about (sorry to the previous chap).
I'm sure you're a very busy man, but you're known here and at the two other places for being a quality chap at purchasing and negotiating the best deals. Whatever your title is at ocuk now it needs to be expanded backwards further to the purchasing stuff also.
So, I REALLY needed a new computer case but instead I bought the Acer 27". That's my impulse buy for the year done me thinks. I might have to sell my 2 GTX580s soon because of the limited VRAM, but I don't play many new games to be honest.
Some good deals on SSD's right there! That sub £200 27' monitor too.
Do the ladies come with the monitors? You might want to specify :p
Maybe its just me but I still find the price of SSD's relative to capacity somewhat offensive for 2015.
This is not new tech anymore, it should not be costing what it does.
