Hi Guys
Stock has landed for the Sica gaming mouse from Asus. After trying one of these out I am really impressed with the mouse. For £29.99 I was expecting a lower quality product but it has a similar feel and tracking response to their much more expensive Gladius mouse but in a body that I find personally more comfortable.
In addition to this, we also have some stock of their new gaming surface.
The 'Whetstone' is a silicone-fabric gaming mouse pad designed for pixel-precise accuracy and exceptional durability. The design is raised which sounds really odd but after using one, it is surprising how smooth and precise the mouse tracks on it.
Both are available from our store right now!
Asus ROG Sica Optical Wired Gaming Mouse @ £29.99 inc VAT
ROG Sica has a compact, ambidextrous design optimized for multiplayer online battle arena (MOBA) gamers of all grip types. It features a simple independent two-button and single clickable scroll-wheel setup, with durable Omron® switches. The left and right mouse buttons are separated from the main mouse body to reduce travel distance to ensure increased button tactility and responsiveness. An improved exclusive easy-swap switch socket design lets users customize click resistance.
ROG Sica packs an optical sensor that tracks at up to 5000 dots per inch (DPI), and at speeds of up to 130 inches per second and 30g acceleration to give users swift, pixel-precise mouse tracking.
The innovative Armoury software lets users customize button functions, performance settings, and ROG logo light effects.
ROG Sica has an iron-gray and red color scheme, a glowing ROG logo and intricate Mayan-stenciled side panels to give it presence. It has a gold-plated USB 2.0 connector, and low-friction Teflon® feet.
Features:
- Designed with input from pro gamers for guaranteed performance and aesthetics
- Left and right buttons are separate from the main body for improved responsiveness
- Easy-swap switch socket for customizable click resistance
- Built-in flash memory to save your favorite profiles
- Exclusive ROG Armoury interface for easy customization of buttons, performance, and light settings.
- 5000 DPI, 130 ips, 30g acceleration and 1000Hz USB polling rate for swift, pixel-precise mouse tracking
Specifications:
- Connection Wired USB 2.0
- Tracking resolution 5000 DPI optical sensor
- Tracking speed 130 inches per second
- Tracking acceleration 1000Hz polling rate
- Switch Omron D2FC-F-7N with easy-swap switch sockets
- ROG switch socket compatibility list:
- Omron D2F Series switches: D2F, D2F-F, D2F-01, D2F-01F
- Omron D2FC Series switches: D2FC-3M, D2FC-F-7N, D2FC-F-7N(10M), D2FC-F-7N(20M) "
- Cable: Gold-plated rubber USB cable (2m in length)
- Operating system compatibility; Windows 8.1, Windows 8, Windows 7.1
- Size 115 x 62 x 39mm (L x W x H)
- Weight 117g (with cable)
Only £29.99 inc VAT.
ORDER NOW
Asus ROG Whetstone Mouse Pad @ £37.99 inc VAT
ROG Whetstone has a non-slip silicone base and an intricate Mayan-inspired textured black fabric surface designed for precise mouse tracking and control. Its portable, rollable design makes it easy to pack and bring to LAN parties.
At just 2mm thick, ROG Whetstone incorporates the latest 8-stage bonding and heat-sealing techniques to ensure durability. Even after extensive use, ROG Whetstone is guaranteed to last, with rounded edges that resist fraying and creasing for always-smooth mouse tracking. ROG Whetstone has an odorless silicone base, with a special water-resistant coat that allows for easy cleaning - simply wash, wipe, and shake to dry.
Specifications:-
- Features Mayan-inspired textured fabric surface for pixel-precise control
- Rollable, portable design
- Durable, odorless, and washable silicone base
- Dimensions 320 x 270 x 2mm (L x W x H)
- Weight 208g
Only £37.99 inc VAT.
ORDER NOW
Features:
Specifications:
ORDER NOW
Specifications:-
- Weight 208g
ORDER NOW
