I didn't realise the orientation before, that's "fan side" up, so no active VRM fan?
Is it possible the AIO block on the GPU also flows through a VRM block? O.O
If so the TAKE MY MONEY!
If you mean RAM with VRM then yes. It was explained that the cooler will cool the GPU + HBM stacks.
So basically like a proper block does it like what you get after-market from EK ?
Well, to help. I did some really hi-tech photoshopping and here's the card in the correct orientation (for most of us looking at it in our PC's).
This **** was difficult, give credit if you use it elsewhere please
Totally havent been following ths thread.
Get the impression the 390x is a modular gpu? PCB looks short?
Ugly? That's a personal preference, I see nothing wrong with it. The way it performs is far more important than how it looks.
I assumed it is short because it saves space with memory being on the Die.
Wouldnt that generate a lot of heat?
that GPU looks horrid, it looks like a metal box for putting shirt buttons in, or boiled sweets, at least AMD are brave i suppose
Nice looking card, if only they did it in green.![]()
