- 18 Jan 2014
- ¯\_ಠ_ಠ_/¯
hi guys just a quick question, does anyone know if there is an update on NVMe SSD's be bootable on the Z87 chipset?
It doesn't explicitly state it on their website so be cautious. Update to the latest BIOS and then have a look within it to see if it provides you with any options.
I copied this for you with the link to the review...
"We saved the best bit of info for last. Samsung plans to release its SM951 in two versions: the AHCI model we tested today and a future NVMe-based drive that's still on the horizon. I really didn't foresee NVMe having significant compatibility issues, but you still have to take this into consideration. The NVMe-capable SSD 750 works in a wide range of computers, but getting the drive to boot into Windows is another story. If you have a motherboard with an Intel 9-series chipset, you should be safe; board vendors are already updating their firmware to support the NVMe interface. Outside of this generation's core logic, though, your odds decline precipitously. Samsung's AHCI-equipped SM951 SSDs naturally work in many 8-series platforms and even several AMD based motherboards."
http://www.tomshardware.com/reviews/intel-750-series-400gb-versus-samsung-sm951-512gb,4143.html
Hope that's of some use to you.
The Samsung ahci is supposed to be getting a bios update that will make it nvme, I'm sure I read that on these forums somewhere.
Maybe I'm dreaming....
