Cooler for I7 4690K
7 Aug 2005
I am running the stock cooler on a I7 4690K CPU, the stock I am told is awful. Can someone recommend a decent aftermarket cooler that is up to £100 budget (ideally a fair bit less)?
if you want cheap you can go for EVO 212, around £25 and is a very good air cooler.
if you want water AIO will be cheaper around £60-120 corsair has some good ones
you can always go for a custom loop and improve/modify as needed.
cheap kits are for around £150
As above we need to know which case first to know what will fit.
I'd get a Noctua NH D14 or D15, d15 is currently the same sort of price only get the D14 if £55 or less.
Got a h110i for £80 last week for my 4690k
Brilliant cooler for the money although not great for all cases due to the size
