 - 7 Aug 2005
My current spec is as follows -
nVidea GeForce Titan Z
Intel Core I7-4790K
EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply
Gigabyte H97M-D3H Micro ATX motherboard
16GB Corsair Vengeance RAM
I would like to buy a new case and proper cooling components for my existing kit. I have done basic builds in the past but am by no means an expert, and would like this one to be that extra bit special and am hoping you can help finalize my build.
I like the look of the Corsair Carbide 540 High Airflow ATX Cube Case Arctic White case which I have seen in rigs elsewhere on OCUK that look great - https://www.overclockers.co.uk/showproduct.php?prodid=CA-168-CS&tool=3
Assuming that choice is a good one, I also need cooling and was looking at Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler - https://www.overclockers.co.uk/showproduct.php?prodid=HS-032-CS
Are these good choices for case & cooling?
Is it worth replacing the stock fans with alternates?
Is there anything else I should add to the list, for example cable management?
I appreciate any feedback
Intel Core I7-4790K
