6pin to 8pin Power on Graphic Card.
The rule of thumb is generally that if your PSU doesn't have the requisite connectors, you are always best off getting a quality unit that has.
What model and wattage is the one you have at present?
And is this actually in a Mac? Or have you fitted it into a PC? And the card you want to connect, is it a gaming card?
Only searched quickly but couldn't find any 12v specs for that PSU. If it's in a PC, I'd be getting a good quality standard ATX one.
It's usually ok. The 8-pin pulls in 150W wheras the 6-pin pulls in 75W. The motherboard gives 75W so as long as the graphics card needs less than 150W you can run it fine off just 1 6-pin socket or 225W with the power from 2 6-pin sockets.
i can see the newer graphic cards use 8pin+ 6pin for power.
can i use one of this:
http://www.ebay.co.uk/itm/Brand-NEW...053?pt=LH_DefaultDomain_3&hash=item3aaac57385
i don't have real 8pin power cable on my PSU.
OCUK sell them mate for £2.89 and better quality one than the one you show.
Akasa PCI-E to PCI-E 2.0 Adapter (AK-CB052)
This cable adapter converts a 6-Pin PCI-E PSU connector to the 8-Pin PCI-E 2.0 standard.
https://www.overclockers.co.uk/showproduct.php?prodid=CB-034-AK&groupid=1929&catid=153
Or
this one
Akasa PCI-E to ATX12V Cable Adapter (AK-CB051) £2.99
This cable adapter converts a 6-Pin PCI-E connector to an 8-pin ATX12V CPU connector. It provides support for dual and quad processor motherboards from a standard ATX power supply.
https://www.overclockers.co.uk/show...ktdetailseite&emcs2=CB-063-AK&emcs3=CB-033-AK
