I have an Antec 300 case from my original OCUK system from years ago. I have also just purchased the Gigabyte GTX 970 G1 Gaming GPU to replace my ageing Radeon HD 5850
Unfortunately, the card is about 33mm too long to fit inside the case!
Rather than return the card, I am now on the hunt for a suitable new case.
Can anyone suggest something similar to the Antec 300, but with the extra length suitable for the GTX 970 G1? Also, ideally, something that will be easy to transfer my existing system into!
At the moment, the following two look like good contenders?
BitFenix Neos ATX Tower Black/Black: https://www.overclockers.co.uk/showproduct.php?prodid=CA-162-BX
Phanteks Enthoo Luxe Full Tower Case - Black: https://www.overclockers.co.uk/showproduct.php?prodid=CA-004-PT
Current full system below:
Case: Antec 300 Three Hundred Ultimate Gaming Case
Power Supply: OCZ StealthXStream II 600W
CPU: Intel Core i5 760 2.80GHz overclocked to 4.00GHz
Motherboard: Asus P7P55-M Intel P55 (Socket 1156) DDR3 Motherboard
Cooler: Akasa Venom CPU Cooler
RAM: Corsair XMS3 4GB (4x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
System Drive: 512MB SSD
Hard Drive 1: 4TB SATA
Hard Drive 2: 4TB SATA
Optical Drive: 22x DVD+RW SATA Dual Layer ReWriter
Any advice much appreciated!
