Toyota MR2 roadster
16 Oct 2007
UK
Is it a mistake to look at a MR2 Roadster (2000 - Mk3?) 1.8 VVT-i with 110k miles on, as an impulse buy? How are they with regards to reliability? Found a very cheap cat C (wing/suspension spring). Tempted to be impulsive.
Category C and the only damage is the wing and one suspension spring? That sounds extremely specific damage, was it shot with a sniper rifle? :p
Apparently so! Possibly a panel or two more. I don't know a huge amount about cars, just found this. Seems very cheap. 12 months MOT. Should last a year, right?
if i remember they have problems with rust and some exhaust problem. But i would have thought the exhaust problem would have been fixed on nearly all of them. Apart from that they are good fun. Good upgrade is to put a 2zz in them :)
oh one other thing they don't have a boot....
Can get lots of issues especially on older cars of oil problems which lead to the bores going oval and that's pretty much the end of the engine. Make sure it's not using any oil or puffing out any blue smoke.
Very much as above, the most important thing here is oil use. Difficulty is up to a point topping it up can keep it going for ages, but it can suddenly burn a lot and total the engine.
Fantastic cars and replacing panels etc is very easy, they just bolt on. Just very much buyer beware, in the same sort of way a cheap rx-8 can be great.
It's fine for a few hundred quid, no more
As above the engines will eventually fail, a 2000 car isn't worth very much to start with and this one's been written off - needs to be throwaway money
For the record I really really like them, but you just need to be realistic about what you're getting into
I had a MkII for about a year and enjoyed it but the boot on it was tiny, I believe that the boot on the MkIII is even smaller so do be sure you can live with it before purchasing. I don't know if the rusting problems continued between the versions but it was certainly what killed mine as a viable car. If it's cheap and you can live with the compromises then all the best with it. :)
Mk3 has no boot, just storage compartments behind the seats. There is still an issue with the rear subframe rusting from the inside out on some cars.
Edit:- On a random note, selling mine was one of my biggest regrets
Great fun handling cars. Engine is gack and will kill itself and drink a lot of oil in the process.
Excellent basis for a track car if you can afford a 2zz upgrade.
I love mine but luggage space is limited. For the record, my 06 plate doesn't suffer and will never suffer from the exhaust/cat problem and it doesn't use any oil at all.
The pre facelift cars, before 2003, were the ones with the pre-cat problem, but hey if the engine blows up you can always throw in a 2ZZ :)
I like mine but I just use it for posing with the roof off. They are fun to drive but certainly not the most chuckable mid engined RWD out there, and yeah there is no room for stuff. I wouldn't use it as a dedicated track car unless it was caged. But I work for a track day organiser so I've seen what uncaged convertibles look like upside down.
Saying that, why not have a bit of fun :)
Because you'll go through a hedge backwards. I wasn't even on the power and managed to spin mine 90 degrees in the wet.
More that they don't have the power and the suspension is too wafty. Mines never actually tried to throw me off the road yet. I'll make sure I don't try too hard though.
I believe the final update to the oval bore issues was in 2005, the post 2003 cars are still occasionally prone to this, though it's far less common. I had a 2003 facelift which had 0 problems, but a friends 2004 ate itself within 3 weeks of starting to burn oil.
Anyway, to answer the op properly, cheap 2000/X cars are probably a landmine.
you dont really pose with the roof off in an Mr2 do you?
