It IS laymans terms![]()
To be fair, I dont have a clue what a joule feels like let alone many joules.
You still up for 4600 joules of energy to be dumped on YOUR leg?
DO YOU WANT A PIECE OF CELERY DUMPED ON YOUR LEG?
Should really be using newtons, you know...as it's force related?
Quite hard to get to a force from mass and velocity.
Easier to look at it in terms of energy
It's pretty easy to get a force from mass and deceleration. Almost as if there's an equation that does exactly that.
The settlement will have to cover any adaptions needed at home and care for however long necessary. It's not quite the same as the US system in total settlement value.
For the insurance company in these cases it will run into the hundreds of thousands If not more. The insurance will have to also cover all nhs medical bills and for major cases that could exceed £100k each. Circa £700 per night per person in hospital.
It also depends if the injured party was an income contributor for the family as the insurance would have to compensate for that too.
From experience of insurance claims, albeit a different industry but similar severity this is going to be expensive.
Depending on what type of insurance and who is at fault, the loss of earnings for the parent group from park closure may also be a factor.
Notwithstanding the technicalities, this is tragic for the families.
But you can't determine the deceleration. Over what distance did the thing come to rest? Do you know? If so you should tell the accident investigators. It will help them greatly-
I'd assume that the abundance of cameras and with some hope, that the cart/rail had meters attached to them to calculate velocities and G forces, would at least give some measure of data.
