***The Vapers Lounge*** 2.0
Status
Not open for further replies.
1:1 (SXK/Infinite) clone on FT for £17 - link
No point spending £50 on a genuine one imo.
Don't want to get into a debate about clones but from experience the Squape R clone & Kayfun V4 clones really left a lot to be desired, could never stop the Squape from leaking & when you see an original next to a clone you really can tell the difference in the materials/engineering from my point of view they are more trouble than they are worth & I have had quite a few clones in the past.
Cheers all
I do agree that some originals tanks are overpriced but would rather have something that was reliable & worked.
I went through 3 Squape clones which cost me £90, with hindsight it would have been better to get the genuine article but were all sold out just before xmas and being impatient didn't want to wait, I ended up getting a seconhand Squape R and stumpy tank for £80 from my local bricks & mortar which to me made sense full price for that little lot should have been £150 ;)
Cheers all
Very well really impressed with it, putting a 50 mm long strip in the Squape B deck not a sign of leakage either.
10 4 inch strips in the pack, once they are pulled apart a bit nice fluffy wicking material & it will last me ages too.
Big question is do I splash out on SX350 Mini M class, already got the S version but temperature control is luring me :)
Cheers all
If you're not burning wicks then there's no real need. YiHi might sort thier paint on future batches. So I'd hang on for that change at least as currently the paint peels super easy. .
Thanks for the tip no burnt wicks here ;)
I suppose its curiousity really on my part.
Cheers all
Couldn't resist, I aint bought any vape gear for months now, been happily vaping on a mutation X on my 100w sigelei @ 0.15ohms at maximum 100w for months, infact I only change my wicks in my coils every few days now, and iv not actually re-coiled for hmm.
:eek: about 3 months!! just dry burn it and wash it even scrub it with a tooth brush gently every time I re-wick, and its good as new still.
So yeah iv ordered a velocity rda :D someone on ebay was selling for 17 quid, ships on the 10th, happy days, looks the bomb so lets see if its as good as it looks :)
Dual coil in the subtank mini reading at .4 ohms and it's chucking out the flavour at 35w! It was tight in there but I got them in. Also had to drill out the juice channels for the 80% vg I use.
The Schwartz, Upside; gets a two tumbs up from me. :D
I tried it in a 0.4ohm dripper and it was ok, but in a 1.4ohm NV it's a lush MTL juice, you really can taste strawberry sour yogurt. If you been turn to the greed crack side; as I know many of your have [insert evil laught]... this is well worth looking at.
For me it might not be a daily vape, but it's certainly going to be a stable in my cupboard for them warm summer days.. yub it's finally summer in manchester.
Picked up one of those as well, £16.99 w/ free shipping! Could've waited for FT to list them but Tobecco clones are usually very good quality.
__
Saw this on http://www.reddit.com/r/ecr_eu - NovaVapes.co.uk
£6 for 30ml of juice, use discount code REDDIT10 for 10% off.
Picked up the Rainbow Dust & Sour Fruit Crush.
Looks like my Ni200 OCC coil is on it's way out, been getting dry hits and took a look at the coil and it's black. Unfortunately I'm stuck at work for the next 5 hours so I'll just have to stick it out until I get home. My own fault for not bringing a spar coil with me.
The coil had lasted around 12 days and has been through around 45ml of juice. Not too bad.
you can remove the tank and dryburn it off... if you turn off TC and set you wattage low and pulse it, that will burn more yunk of it quicker. but I just normally rise/jet it under the tap and dryburn it with tc on, that's what TC is therefore :) stopping the cotton from burning.
Got a linky for the dripper?
Here you go man!
__
Saw them on 3FVape as well. I haven't used them before so I can't comment on that front, but it works out at around £9.50 including shipping via epacket (through China)
__
I think I'll cop some of this as well. Pre-made Clapton wire from Youde - £5 meters of 26/32g for £4 odd - doesn't ship until the end of June though.
Status
