** TECH LABS PRESENTS - 980TI **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Its here
Confirmation from Block Vendors today that their Titan X blocks are fully compatible with the 980TI board
More versions will be available over the next few weeks when we see blocks from other vendors.
OcUK Tech Labs H2O Custom GeForce GTX 980 Ti 6144MB GDDR5 PCI-Express Graphics Card - EKWB Edition From £659.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 980 Ti combines a fast single GPU gaming card with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
With a choice of the finest cooling solutions from EK Water Blocks, this card looks incredible no matter what finish you choose.
Never has a pre built watercooled card been such a complete package!
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
- Titan X Cooler (Silver shroud)
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1000MHz
- Core Boost Clock: 1075MHz
- Memory Clock: 7010MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 1x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 2yr
From £659.99 inc VAT.
ORDER NOW
Out of interest, for someone who has never done watercoling but always been tempted, what is the minimum amount of extra equipment needed to use this?
Minimum would be a radiator, pump, tubing, some fans and the reservoir, as well as the fittings to join the tubing to the components, and obviously fluid itself. You get pump/res combos.
A cpu waterblock would obviously be nice as well, to get everything underwater.
Roughly another £100 - £200 outlay depending upon what you buy.
