The GTX 980 Ti owners thread.
I will :)
Not the least bit fussed what AMD is bringing out...
If it changes prices... meh. Won't be spending this much on GPU's ever again though!
Would anyone with a 980Ti be kind enough to check the FPS for me on pcars with the following:
1080p
All settings MAX - inc AA & AF
Imola
Audi R8 LMS Ultra
If you could let me know what the max/min FPS around a lap is that would be great.
Considering switching my 290x2 for a 980Ti + ££££
[/URL][/IMG]cant wait to install this and have a play will get ek
[/URL][/IMG] block and backplate delivered in a couple of days
So, what are the odds of hitting 1500 on the core on these under water?
Or will that likely require custom BIOS?
I don't think there is anything in BIOS you can't do with overclocking software.
Just depends how good your chip is and if the card can deliver enough power and stay cool.
Custom BIOS can raise the TDP and also give you a fixed or increased voltage.
1500 should be easy on water, jayztwocents hit 1484 I think it was with the hybrid.
I thought EVGA precision and the like can increase board power and voltage too?
Or can BIOS mod go further than the software can?
Custom BIOS allows even further.
For example the BIOS I use on my TX allows 425w power draw with the power slider maxed, the stock bios is 350w or something I believe with the slider maxed.
Welcome and on TROH.:)
The Roll of Honour.
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
Well, a slight update to my current experience with the 980ti. No doubt its a heater but the last few gaming sessions havent been that bad actually in this department.
Last session was BF4 Using ultra preset @ 3440x1440 locked to 60 fps and vsync enabled.
Through out the entire match the fps was steady and didnt dip and usage went between 35-60% :P so much performance in this card. Card didnt go above 69 degrees with a custom fancurve reaching 55%. Its a little noisy due to the air getting tunneled through the heatsink but with a pair of headphones on as i usually use i didnt notice it one bit.
Its so sweet to be able to push fps=hz at such a high resolution monitor with maximum details even in games like Dragon Age INQ.
I would however recommend any 980ti to download the gsync hotfix driver from nvidia ->HERE<-. I got annoying stuttering on the release driver whenever i used vsync and this driver for whatever reason have fixed it..
Good stuff. Out of curiosity what settings can you apply in Dragon Age Inquisition whilst maintaining a rock solid 60 FPS?
On my Titan X at 1350mhz I could do everything maxed, MSAA turned off, and resolution scaling lowered to 90%. That gave me 60 FPS even in intense fights.
You guys ever just played a game without fannying around ?
Lol, if you want plug and play, go console.
I enjoy messing about with game settings, tinkering in ini files. Getting the best visuals possible. It's part of PC gaming to me.
Be interesting to compare Dragon Age on these in SLI against 3 x 290X 8GB, with everything maxed.
According to overlay can get up to 6.5GB vram usage on current cards, so will be interesting to see if I get any stutter of any kind on the 980 ti's...
Don't have very much I can do comparisons of, as not a lot installed currently. Will do a heaven bench tonight, Firestrike bench, and I believe DAI has an in-built, so can do that.
Other games installed:
FC4, Beyond Earth, Witcher 3, Advanced warfare.
Do any of those have benches built in?
FC4 defo doesn't. What resolution do you play at?
EDIT: NVM just saw your monitor.
Ive maxed absolutely everything with the exception of MSAA which is turned off. Now my testing in Dragon Age has only been inside the big keep you get half way through the game. Seems like a brutal place considering my old 780 lightning would throw up whenever i tried 3440x1440.. I dont know if there are any worse places performance wise.
