- 14 Jan 2014
All,
Had a TX for a couple of months and been chatting with OCuk with regard to RMA because I seem to have the following problem.
When using the display port outlet from the TX I'm having resolution problems (constantly reverting back to lowest resolution) and I have green lines and dashes (snow) all over the screen.
I can boot to Bios and then into the OS (Win 8.1) but I cant access Nvidia control panel and I tried updating the drivers which failed. The card powers up it seems everything lights up, fan running etc. I've not yet checked in device manager whether it is actually being recognised yet which is the next step.
OCuk have advised flashing the Bios, which I have no experience of, I have a Asus Z87 Sabertooth and I understand it is relatively easy and can be done automatically with some software.
I've also tried reseating the card, but not in a different PCI slot. Might be another option.
Any thoughts?
Everything was running fine for 6 weeks or so and only the last couple of weeks have I had this issue. Where is has got progressively worse, to now being a permanent problem.
Cheers.
Any thoughts?
Cheers.
