Hi all, looking for a bit of help. Currently contemplating a GPU upgrade in the next few weeks, and the 960 seems about right for what I want to spend. Currently I'm on a 6870 which still performs surprisingly well for what it is, but my main concern is down to heat and power. My PC is a Dell XPS 8300 with the standard OEM 400W PSU, so ideally any new GPU needs to use the same (or less) power than the 6870 otherwise I fear I'll be putting the PSU quite close to its limits. Anyone know if the 960 would fit this criteria? Reviews of the 960 unsurprisingly don't seem to compare it to older cards.
I did look at the R9 285 but its at-load power usage is higher than the 6870 so I'm not too comfortable with that. The cooler running of the 960 appeals too, seeing as I don't have much in the way of case cooling.
Cheers for any help.
