- 7 Dec 2008
It will be m8, the ACX 2.0 on my 980's are awesome![]()
And I hear they are shipping this Friday, so the wait might not be as long as you first thought.
Thanks I am Changing From 2 780 SC Reference Cards Which are not too noisy just fancied a change from the Reference Coolers and Something a bit cooler and quieter in my rig and the white led logo will go better with my black and white theme.
It'll be a good switch m8, just make sure the airflow in your case is pretty decent and you'll be fine![]()
Thanks , Installing in A Corsair 760t With All AF140s Installed Running Medium RPM Should Be Ok.
Is that normal Firestrike, Extreme or Ultra?
I ask because for SLI on normal those scores are terribly low.
Here's what my two cards gets: 22102
http://www.3dmark.com/3dm/7218688
Hi Ben, any news on the Hybrids?
Sorry, its for Extreme
In normal Firestrike i get 30791
that would put you rank 8 on firestrike normal with 2 gpu's. Considering the GPU's that high have 1500-2000mhz core clock.Are you surethat would put you rank 8 on firestrike normal with 2 gpu's. Considering the GPU's that high have 1500-2000mhz core clock.
The inflated prices really bugging me...
I want to order my cards![]()
Hah sorry, I was quoting you the graphics score
http://www.3dmark.com/fs/5034881
EDIT: with a bit of tweaking I am just a little short of the top 100 @ 24145
http://www.3dmark.com/3dm/7259227
, Still a great score non the less!. Just waiting for my 980 ti's now
.Aye EVGA have a great warranty and customer support mate.
Can anyone advise which overclocked cards are compatible with the EK full cover Titan blocks? I'm assuming the MSI Gaming one is as I current have a 780 MSI Gaming under water. I'm looking for the fastest card to put under water.
