causes or warped discs?
leaving your foot on the brake after heavy braking leaves pad deposits on the disc and has the same feel of warped discs
Overtightening/unevenly tightnened wheel nuts can also cause it
Malfunctioning calipers are also a factor
Also crap/cheap discs do this :p
Rust build up between the mounting face and the disc is pretty common reason for that warped disc feel as well. So many issues can be solved by a good strip and clean.
Not cleaning the drive flange face on fitting a new disc.
Poor quality manufacture.
Over heating / lack of adequate cooling
Incorrect bed in procedure.
Applying the brake pads in a stationary position for an extended period on a hot disc.
yeah most of the above is what i had been thinking of my self
just trying to figure out if its something i can avoid around 12k to a set of discs aint great!
but least its being covered under warranty
