I recently picked up the Gigabyte Z97X-SOC and a 4790k in last weeks "this week only deals".
Now, I have that paired with G.Skill 8GB (2x4GB) DDR3 2400MHz TridentX using nothing more than X.M.P. (These damned 4790k's run freaking hot).
But frequently if I reboot the system Ill get the "Boot failure detected", it will then take a further 3 resets to be able to even use the motherboard/keyboard to select enter BIOS. Which is freaking annoying and makes me miss my P6T Deluxe.
In the BIOS I can literally F10, save and boot to windows just fine. Ive flashed the BIOS to F6, so it shouldnt be a BIOS issue. A google search has me seemingly alone on the issue. Which is why Ive turned to you fine folks.
Anyone using this board came across this issue or have any ideas on how to resolve it? I have "loaded optimized defaults" and yet the issues returns, not every reboot, just frequently. Its more common on a reboot than from a cold start.
Cheers,
Nige
Cheers,
Nige
