Coast to Coast - for an amateur!
Quick update....
Been out on 3 rides so far,
11 miles
11 miles
13 miles
Each ride a little easier than the last and building up slowly, but tbh they were quite comfortable. Still need some gear, so far only bought:
*a new pump as the last one just didn't cut
*decent lights (for being seen)
To limit my spends, as this could turn out to be quite expensive, I plan to borrow a few things, so my essential items list is currently:
*Shorts - I have a sore arse already!
*Bottle and holder
*Gloves
*Bar ends
*2x Inner Tubes
*Multitool
*Vest perhaps, but not sure whether to bother.
I'd get those tubes up to the top of the list.
Your new pump is pretty much useless if you dont have spare tubes with you.
What do you mean by vest? If you mean a jersey, get one. If you mean a base layer, you can probably live without if the weather is decent.
Will do, the list wasn't necessarily in order as such... more a semi order :p
That's what I was thinking... OK, without wanting to be a total scrimp merchant, what would you recommend shorts and vest wise that is lowish/mid range, but still reasonable i.e. bang for buck ( or miles for buck :D) I'm trying to keep the ever increasing costs down a bit.
Was also thinking of baggy shorts rather than the tight shorts... don't think I'm quite ready for that yet ;)
Wiggle have cheap base layers at the moment:
£5 short sleeve
£7 long sleeve
I have a short sleeve one. It's nothing fancy but it does the job.
Not sure what the best value shorts are just now - possibly the ones in decathlon? I'll wait to see if anybody else has any suggestions.
Dont get baggy shorts though. If you must, get some proper cycling shorts and wear baggy shorts over the top but even then you can still get seams and folds of material getting in the way.
£5 short sleeve
£7 long sleeve
Thanks for that, they are now added to my shopping list :)
Spec me some shorts next please :)
I'm planning on doing it in one day next year, and I expect it to be quite hard work... Particularly if I go the route I've plotted out which takes in a cat 2 up the highest A road in the country.
It should be over 3 days. As long as he's not carrying the kitchen sink on his back/in panniers ;)
Agreed, over 3 days it shouldn't be that hard - though once again it's all relative. I'm sure it will feel hard for the OP.
You do make a good point though...
@Egon. Definitely definitely do a practice ride whilst fully loaded with everything you intend to carry. Be sure to make it relatively long and with a few hills. After you do that, go back and remove all the stuff you thought you needed but now realise you don't :p
I'm looking forward to it, I think the first day is going to be challenging, but yeah, spread over 3 days it should be doable for us. The posts in this thread so far have been encouraging, thanks :)
I don't plan to carry much, small back pack with a change of clothes for the evening, plus the essentials as already listed and that's about it.
We've got a 40mile ride planned for the week before, cycling a circular from Darlington to Hartlepool. I'm building the distances up slowly and I'm planning a 20m ride this weekend. Most of all, I'm enjoying it, the evening rides have been relaxing and I've been needing something to motivate me into improving my fitness and diet so it's win win really!
Get in the gear you want to climb the hill in at the bottom of the climb and establish a rhythm you can stick to. You just want to get to the top, don't try and break any records ;)
Good luck.
Another update for those interested in following my progress:
I've purchased a fairly cheap set of gear from Wiggle - jersey, shorts, gloves and glasses - which make me feel less of a noob, but do genuinely enhance the riding experience. Happy with everything, but need still a proper set of cycling shorts for the big event.
I've clocked a couple of 20 miles rides now, I'm finding my fitness has improved (I've dropped 4 pounds) and I'm getting faster too. Every ride I'm finding I can push myself a little further/harder/faster. I've also tackled a few hills... this is the worrying part, because I'm bloody knackered on anything too steep.
I'm finding my thighs have a very mild constant ache in them now, doesn't it affect my riding at all though, it's just my legs telling me the ride last night was tough! Although last night it hurt a little bit on the inside leg behind the knee... not had that before. Makes me wonder if I'm over doing it or my riding position is poor.
Here's my profile on strava so you can see what I've done and offer any advice on future rides... if you can be bothered ;)
https://www.strava.com/athletes/5851704
