Suspended
- 22 Apr 2015
NewRetroArcade 3.0 - Oculus Rift 80's ARCADE!
WOW, I stumbled across this earlier and I have to say it is absolutely amazing..
NewRetroArcade 3.0 built using the Unreal 4 engine, it's a 80's style arcade simulator, you can edit and build your own arcade as well! (typo error in thread title, it's 3.0 not 2.0)
It can be used with Oculus Rift for even more realism but you don't need the rift to play.
You can play every game and arcade cabinet inside it
I highly recommend you check it out! it's fantastic and brings back some memories of the arcade culture as a kid!
You can even add your own music and pick up little tape cassettes from a table and put them in a boom box to play your music!
it has a SNES machine as well which you can pick up the cartridges and swap them over etc.. fantastic stuff.
There are also 3 secrets in the game, see if you can find them! (hint: the broken arcade machine can be switched on, but how?
http://digitalcybercherries.com/
it has a SNES machine as well which you can pick up the cartridges and swap them over etc.. fantastic stuff.There are also 3 secrets in the game, see if you can find them! (hint: the broken arcade machine can be switched on, but how?
)http://digitalcybercherries.com/
What do you mean? you can play all the games in it?
