Does a router exist, that just ****ing works?!
27 Jul 2004
Yancashire
As title. On my third or so router in about 5 years. All have been the same, seem to be great for about 6 months, and then after a while constantly need rebooting/ turning off and on again.
At the moment pretty much have to do this daily. One device in the house will work ok, and then another won't etc etc. Probably about 10 wireless devices in the house at a guess.
Tried setting channel to auto, to 1, 6 or 11 (as advised before), have assigned a static ip address for a few devices. Does not seem to make any difference.
Getting very very tiresome. I don't need/ want anything fancy. Can't get fibre where I live either, max download speed is about 7Mbits (is it bits, not sure?) Less than 1MB per second download speeds anyway, I know that.
So, any recommendations for a good router that just works, and doesn't need rebooting al the time?
Nothing fancy, a few Netgear Dg834 whatevers, and currently using a D-Link DSL-3680.
As mentioned, they seem to work great for a few months, and then start to cause problems.
I'm not an expert on routers at all. What do I need to do, or look out for if buying a new one?
DSL or cable?
Update the firmware on your current router, then reset it to default and set it back up again.
DSL or cable?
It's DSL. Firmware is the latest
Also, I've reset the router just (physically pressing the little indented reset button on the body). All the basic info now set up and back as was.
Just been reading up about wifi interference. There is one thing - I recently set up a crappy cable and wireless cordless telephone that my parents no longer wanted. This most likely operates on the 2.4ghz band, which can interfere with wifi routers? Is that right? But would it be interfering if it's not being used? I mean it's just sat there in the cradle 99.9% of the time, downstairs in another room. Surely it's not 'broadcasting' if it's not making or receiving a call?
I can sack the phone if needs be. Do I need to buy a fancy dual band router though anyway?
Get a draytek 2860n we use them for fibre and adsl, very good but not cheap, are you sure it's not a line fault or noise on the line and not faulty routers ?
Is your router/s in a place which could overheat them? (small cupboard, cabinet etc)?
I have a DG834GT still hanging around currently unused and it has performed flawlessly (and still does AFAIK) for well over 5 years.
It's an internal 'wifi' issue that's the problem. ie various wireless devices (ipad, iphone, PS4, NOWtv box etc) just will not connect to the internet sometimes, unless I reboot the router or turn off and on again. My desktop PC is physically connected to the router with a cable and I hardly ever have internet issues with that.
It's not over heating or anything like that either. Is on a desk in the open.
Not a line fault either, and that wouldn't affect wifi would it?. Line noise and attenuation figures all good and constant too:
Up:20.7
Down:40.5
SN margin:
Up:11.9
Down:12.0
One thing I did notice is that on the basic quick start summary page "Total errors seconds:" was 70 something. Since re-setting the whole router this figure is now at 0 and has been for the last 30 mins or so.
Probably one of your i-devices causing issues if you do some searching around there appears to be loads of posts about ipads and the like either not connecting or stopping routers connecting to devices.
I get lynched every time I suggest this, but when I first got Infinity I connected the Openreach modem to an AirPort Extreme (dual band wireless N), and didn't touch it for 3 years until I moved out.
They have no features, but they are stable and the Wi-Fi works.
Only time my Black Knight is switched off is when I decide to move it. Uptime is never more than a hundred days or so because I do move it quite often.
Apple Airport Extreme -- absolutely ROCK SOLID, has never once in 18 months needed a reboot. Not cheap, but you get what you pay for.
Well, decided I'm going to get a new modem/ router combo. Will try out a dual band TP link D2 Archer I think and see how that goes....
Unless you want to do something simple like DHCP reservations, which aren't exactly simple. Or host Open VPN, or anything else routers half the price manage perfectly which also never need rebooting.
I'm going to beg to disagree. None of the consumer brands (apart from Apple) are known for being stable; as far as I'm concerned that is a simple fact. Feature-packed? Absolutely. Stable? No.
I value stability extremely highly. There's enough stress in my life as it is, without having to deal with an unhappy wife that can't get on the Internet.
There's plenty of stable routers that cost half of what the Apple does though, although I'm not surprised people buy into the brand believing it's better because it costs more. "You get what you pay for" doesn't really work well with technology.
I've been running an Asus RT-N66U on stock firmware for the past 2 years and never once needed to reboot it. Been solid as a rock.
Have just upgraded to an Asus RT-AC87U and so far has been much the same, stability wise. Am using the RT-N66U as an access point to extend the wireless range better across the house.
Jim
