 - 30 Oct 2007
Hello.
I've had a CoolIT Vantage liquid CPU cooler installed in my PC for a few years now. Over the years I have had an occasional problem where the cooler will beep a warning at me. Each time a quick blast with some compressed air on the fans has solved the issue... untill today.
I have disassembled the fans and completely cleaned the radiator, and removed the pump from the CPU, cleaned off the old thermal paste, and reapplied some new. But no matter what I try, I keep getting the warning beep.
I am not 100% sure what the display is showing, but if I'm reading it correctly its saying the pump isn't running fast enough, around 500rpm. I have ordered a new cooler (a Corsair Hydro 105 ), but I just wondered if anyone knew why my old cooler decided to act up. Do you think the pump has had it? Is there anything else I could try before my new cooler arrives?
