Hey Guys
Rad availability from EK has always been a sticking point for many users.
We have always struggled to get good stock allocation from them before until now.
The EK-CoolStream XE Radiator series is a serious piece of kit and the first real top class radiator the brand have released.
This radiator offers best cooling capacity in the 60mm thick radiator class: Triple stack copper fins provide massive surface area while the parallel flow cooling chambers reduce hydraulic flow resistance to a minimum.
Simply put, the XE series is designed with performance in mind. They look fantastic too. With 16 Fins per inch, you will see incredible performance with slower fans that use high static pressure. A silent system is really achievable with these radiators paired with an EK Vardar fan or even an OcUK FQ121WC on a fan controller.
EK Water Blocks EK-CoolStream XE 120 (Single) @ £42.95 inc VAT
Only £42.95 inc VAT.
ORDER NOW
EK Water Blocks EK-CoolStream XE 240 (Double) @ £61.99 inc VAT
Only £61.99 inc VAT.
ORDER NOW
EK Water Blocks EK-CoolStream XE 360 (Triple) @ £79.99 inc VAT
Only £79.99 inc VAT.
ORDER NOW
EK Water Blocks EK-CoolStream XE 480 (Quad) @ £99.95 inc VAT
Only £99.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
