Mondeo 2.5T seems to have more grunt when cold
14 Nov 2012
Chesterfield
So I've been driving my car too and from work for a while now and this morning I noticed that the car, when cold, seemed to have more grunt when putting my foot down. Obviously I didn't rag it as it was cold, but it seemed more responsive.
When its warmed up, it doesn't seem to respond as well, its not awful but its no where near as responsive as it is when cold - what could be causing this?
I honestly don't know if it has an intercooler, I'm assuming it would but I've not actually checked.
Could it just be the hotter air under the bonnet causing the decrease in responsiveness?
Possibly check the cold air feed to the filter isn't blocked, or consider adding an extra feed to help the cold air get to the filter.
Are you using the standard airbox and filter or have you replaced with a cone filter?
I had thought about changing to a cone filter as other 2.5T Mondy drivers who have done so have reported the car to be more responsive on the pedal. I'm currently using the stock airbox, feed & filter.
stock filterbox is good, just get a panel element if anything,
I've done a fair bit of reading about this recently, and the intercooler is a bit small for the job, most upgrade to a focus RS one (to save some pennies) or a proper aftermarket jobby.
**edit also check its not 'bugged up', amazing how much crap comes out witha jetwash through the IC
Heat soak. Get a bigger intercooler.
I had thought about doing that actually.....pretty straightforward?
Panel Element? You mean a new/better filter?
If you get one made for the mondeo yes. Otherwise it might involve drilling new hanging / bolting points, cutting metal to fit a non-fitting cooler and cutting new hosing. Depends on how handy you are with the tools and whether or not you want to cut the front of the car up, compared to dropping in a made for replacement which you can return to stock if you ever sell.
Quick google says JW racing have one made specifically for the mk4.
http://j-w-racing.co.uk/product.php/8108/3115/spec___r_alloy_intercooler_mondeo_2_5t
Sure airtec do a cooler for the 2.5
But I don't think it's your ic if the cars stock. Maybe a quick diagnostic might be in order first
That was quick - thanks :) Not sure I'd want to tackle this on my own, but it's just a few hoses right :p ;)
Not even that ran outside and grabbed you two pics, unscrew the two screws.
slide it out (have the move the plastic front panel but it moves out of the way without too much effort.
**oops missed the IC fitting post rofl, ignore
^^ HAHA :D Yeah, I could do the panel filter, but it would seem the IC should be fairly straight forward considering its an identical size.
Where you based BTW?
I've noticed my ST220 is the same especially on a long drive in hot weather the acceleration goes flat as a pancake.
Yeah, I'm happy to buy the J-W-Racing IC, but if I can get roughly the same performance for less that's a bonus. I'm getting a remap in January, so this should help too!
I've noticed this in all of my large (ish) engined BMW's, all go like a train in the early hours on the way to work but coming home when it's warm (hardly hot though) they do feel less responsive.
Curiously though, I didn't feel this drop off in the smaller engined 318's I've owned, but certainly in the 3 M52 engined six pots and my current M54 530i especially, this is very flat on a hot day, no fault codes though when I got it read recently.
I'm guessing it's down to heat soak, my truck though is unaffected by heat or cold, I'd have thought a 13litre turbo diesel would be more susceptible to this but apparently not.
