Apprentice Watercooling Help Corsair240
4 Jun 2015
Hi,
I'm looking to replicate this build, my first time watercooling and I have a few questions.
1/ How did he mount that pump there?
2/ Should I get a ITX board or can I stick with my MATX?
3/ Can I still mount a Rad underneath GPU if im using a OcUK Tech Labs H2O Custom GeForce GTX 980 Ti?
Any help would be appreciated, a is 7950 L=275, GTX980Ti L=282mm.
Current Parts List *Will Update*
- Darkside LP240 Slim Rad x 2
- EK X-RES 100 CSQ Pump Top / Res
- Windy5000
Card used in rig is a 7950.
Image/Thread Link
Hi,
1.He used a EK-Uni pump holder. It mounts on to any 120mm fan mount(in this case the Rad).You then mount the pump/res combo to that.
2.You will have to get an ITX board i fink,strongly doubt you could mount a rad plus fans their and squeeze in a mATX board.Measure up the space your current board has to the case bottom to know for sure
3.Yea you will be fine using any card with a block attached assuming you use a slim radiator
You'll definitely need an mitx board. I have matx in that case and it will not fit a bottom rad.
Something else you should be wary of is the total depth of the VGA cooler. It's very possible it will foul on the side panel/window.
I've seen people remove the window and mount it on the outside to overcome this.
Hey,
I calculated it just might fit, however the tube will be left to arch over the card. Not sure about multiple hard fittings and using them through the letter covers to the gpu and cpu.
I doubt I could attempt that either, what If I used a 240mm Rad underneath the GPU and a 120mm Rad nearer to the cpu.
yes should be fine, i have one 360 for my cpu and gpu temps are fine.
Ok, however it seems that the Darkside240mm Rad makes it a little difficult to get the bend from the reservoir to the radiator. The Gpu measures 282mm, bear in mind that I'm going for a 120mm slim line radiator at the top. Is it possible to connect the loop?
Someone once told me that its best to have the connections direct as possible.
