 - 22 Oct 2004
 - Berkland
Ok, so a purpose built flat, built in the late 80s (88).  How typically do you think these would be built?
The reason I am asking is that our flat appears to have a water leak, well, the laminate and ply flooring as appeared to have bowed and a dark mould like substance has appeared between the ply and laminate.
The flat in question is a top floor flat, and I would assume the floor underneath is concrete? Is that most likely? Would it even be possible to run a pipe in a concrete floor such as that?
