sous vide / bbq beef
Don
18 Oct 2002
Chon Buri, Thailand
Off to a bbq at weekend and I am going to sous vide a joint of beef to be put on bbq while there
I have done the beef before (topside works well , 55C for 24-30 hours)
thing is I want the out a rub or maybe a bbq sauce
firstly any suggestions and secondly do I out the rub on when it goes in the vac bag or just before the bbq?
One thing to keep in mind is that you may want to reserve about half the rub for after the sous vide step. There are some schools of thought that the rub flavour is amplified by sous vide and aside from that, adding more rub (i.e. the half you reserved, so your normal amount) prior to the bbq step will help provide a better surface for the bark.
Personally I've not had amazing luck with sous vide and bbq but I know others have. I'll be interested to hear how you find it.
I've done a plain joint of beef SV with nothing but thyme for a friend who was going away and having a BBQ, that came out amazing
thanks for the advice so far folks :)
