MSI teasing GeForce GTX 980 Ti Lightning
5 Sep 2011
Surrey
Source: http://videocardz.com/56288/msi-teasing-geforce-gtx-980-ti-lightning
In case you don’t remember, MSI has not released GM204-based Lightning, because ‘they were waiting for the big Maxwell’.
Well, the Big Maxwell is already here, so it’s about time we see the successor to GTX 780 Ti Lighting (the Big Kepler).
MSI GTX 980 Ti Lightning would be most powerful GTX 980 Ti model from MSI’s garage. We do not expect to see TITAN-X Lightning anytime soon (actually ever), so this card could potentially be the actual MSI’s flagship GPU till Pascal.
MSI GTX 980Ti Lightning is said to arrive with updated TriFrozr cooling solution.
It is yet unclear if company is planning Radeon Fury X Lightning (sounds odd, does anyone have any better idea for the name?).
Given the layout it's likely to be very similar to the 290x vreg layout and have the same cooler - same colour scheme to boot given the artwork.
Only thing that I want to know personally is are they binning these, or like with the 290X could we be left with an expensive paperweight core, and an awesome pcb and cooler. Probably the best cooler I've ever used :)
They binned the 290x gpu on the lightning as far as I know. Also the 290x Lightning had 2x8 and 1x6 connectors not just 2x8 looks like this absorbs less power :D
This or the Classified could peak my attention.
Something people waiting for Fury should keep in mind is we've not really seen what GM200 can really do other than obviously with eboards and hard mods
I'd love to know to what clocks in that case...the other thing is that the 290x throttles the amperage past a certain point and I can't remember where exactly. It was actually more beneficial to buy reference boards made by Sapphire when pushing the top end. To overcome the throttling one has to obtain a copy of MSI Afterburner Extreme, which isn't something you can get on request at a whim. Basically the AMD boards are so tanked in the vreg department anyway, there's not much point if you're planning on stripping the card of the cooler.
Totally different story with this card, as the reference Flextronic boards are mediocre at best and at worst down right adequate for normal (non 'rag it' operation :p)
I've removed that photo as it was of the 680 PCB ;). They follow the same layout however, but it's likely to have similar power input to the 290x
True, the beefed up boards on the Classy/Lightnings can take some serious hammer.
From what I can remember, the Lightnings are not binned.
I didn't think they were either. Mine could do 1280Mhz with close to 1.5v lol.
+1
I think the Fury will have very little overclocking headroom compared to the GM200 cards and if NV feel under pressure they could very easily release reference cards with a 1200mhz+ base clock.
As to the non ref ones I think the Kingpin version will be both fast and expensive.
Full credit to EVGA with the 980 Ti cards they have said up front that there will be a Kingpin version so people know what's what.
1280 is a very good clock for a 290X. Not many reached that on air.
Plenty struggled on water to reach that speed.
+1
**** the Kingpin. I'd take my chances with the vanilla Classified.
That's a testament to the cooler more than anything. The VRM didn't exceed 70c at that voltage if the software polling was to be believed. It's a behemoth. I doubt reviewers are at liberty to try these things though lol :p
Now try fitting 3 of them in one system though :p
+1
Kingpin Ti could well come with a 1200 base clock. The GTX has a base clock of just under 1300 core so I'd expect the Ti to come in at slightly less. I don't think NVIDIA would bother with a clock ramped reference card. Like the 390X for example :p
Sorrysorry!
I prefer MSI's TwinFrozr cooler, that thing is so damn quiet. Unless the lightning is also just as capable of quietness?
