Think I will have to dig through my games tomorrow and find something loaded with nvidia features...
Witcher with Hairworks on
To be honest your attitude is appalling.
Gibbo stated Around 5 units came in, that doesn't mean 5 units came in it is a rough estimate. Over the past two weeks you have been doing nothing but slating and whining.
ETA: 26/06/15
They have stated a big delivery next week. Deal with it and stop moaning.
G1's are worth waiting for imo Agnes, they look to be a verrrrrrrrry good card![]()
Yea man! I'm still shocked at the noise video posted.
Can't wait though.
I will be putting mine under water tomorrow. What clocks you getting?
Awesome. I've got two superclocked ACXs coming which I plan to leave at stock for now. Soon I'll put them under water when the hydrocoppers are readily available and custom loop my entire system. 1500+ will make a big difference for sure. These chips love a good overclock.
How is everyone going with overclocking?
I have a reference model and was pushing +250 on the core and +400 on memory.
I thought I was all good until I actually started to play a game (Dying Light). I got a crash after about 5mins.
I started to drop back on both but was noticing that I kept hitting the 110% power limit so the clock speed kept fluctuating/dropping.
I've currently now gone with +225 on the core and nothing on the memory which gives me a stable 1402Mhz (no fluctuating).
Is it best to push the core some more until I reach the limit here? I assume if I'm hitting the power limit, it's wise to back off?
Should I push the core and leave the memory or now to try push the memory and leave the core at 225??
I'm confused!! ha ha.
Is there a way to increase the power limit passed 110? (obviously a better cooling solution would probably be needed if it was possible)
Any input appreciated!!!
ETA: 26/06/15
Much better photo than last time.
Thats why I got rid of the 980 Inno because that little fan on top makes a really annoying whine that I could hear even with my case under the desk.
Video didnt mention what RPM they were running at ? 100% ?
I was a bit afraid at the noise reports after I ordered mine but to be honest its quieter than you think. Mine is really quiet at idle and it doesnt start to get louder till it hits 50% yet I had Heaven running for an hour earlier and it maxed out at the expected 84c but the fan was still at 45%. Really really impressed with the reference cooler. Boosts to 1189Mhz too not bad when its only supposed to do 1076Mhz.
I am now quite worried about my Gigabyte G1 purchase, I was hoping for a quiet card but that video has me rattled.
I'm going from experience. I previously had this card: http://www.gigabyte.com/products/product-page.aspx?pid=4673#ov
Which has a very similar cooler (identical really) and I have a little Lian Li case which housed it. In the living room, I would game and put that card to it's limits. And honestly, I never heard anything. It never sounded loud. Coil whine was bad, but the fan was almost silent.
So going off that, I'm taking that video with a pinch of salt.
I have also owned the windforce gigiabyte cards like the 780 and the Ti and the 980 and they all have the same cooler and to be honest the fans did not bother me so I agree with agnes
Both of your comments have made me feel a lot more at ease now, I must thank you both for your prompt replies, I hope I have a similar experience to you both, I must also factor in that nobody games in silence, I suppose it's irrelevant to some degree if you can't hear the card over general game play.
Once again, I thank you.
Here's to hoping we receive our cards before/on Wednesday if you have made the same purchase.
