So is Fiji confirmed GloFo or not?
AMD should price their cards as they did the 290X/290.
The Flagship Fiji being 450+, and the second tier Fiji being 350+.
300 pound shouldn't be an upgrade option for someone currently with a 290X.
It needs to be way way way under £500, a 290 is under £250, what 290 owner is going to look at a 290X rebox for £350 and how many 290X owners who didn't buy their GPU's early are going to up their budget by £200?
290/X owners with £300 budgets have nothing, 280X owners with £300 budgets have nothing if the rumored £350 Price is correct.
Well, there is always Nvidia. if these rumors are true AMD are about to fall flat on their face and probably never recover.
If a full Fiji is no faster than a 980TI then a cut Fiji isn't going to be much faster than a 980, be that as it may £350 for a cut Fiji may still not be cheap enough if it also has a 300 watt TDP.
I'm pretty sure (as in 99.9%) that all the data that's not included in the card's bios is just pulled from the gpu-z database. AMD/AIBs don't put card release dates, transistor counts, manufacturing nodes, die sizes etc. into the bios. Those are manually added into the databse by techpowerup staff after launch when they've been confirmed.
The GPU gets detected by the device ID and then clocks etc. info is gathered because that's something that gpu-z does have access to.
Since the database hasn't properly been updated for the 300 series the gpu-z application is still pulling the 200 series information even though the bios/drivers of the card gets read as 300 series.
So until gpu-z and the databases get properly updated GPU-Z will always show the R9 290 release date that they have logged in their database:
http://www.techpowerup.com/gpudb/2397/radeon-r9-290.html
But again, it makes very little difference. The GPUID is for hawaii and the clocks etc. are quite clear.
You're always telling us how AMD can't keep doing these low prices.
Like I say, I just want 40% over my 290X at 450.
If I can get 30% at 350, I'll get a cut Fiji and clock it.
The fury has to be in 295X2 ball park to kill the titian.
The 390X will have to match or beat the 980Ti, if not then its game over for AMD!![]()
The Fury is not going to do anything to the Titan X as it only comes with 4gb of memory making it a non contest @2160p.![]()
Says Mystic Meg.
