I read somewhere ( maybe on here ) the Fury X will run at 1750 on the core. Could that possible be true?
Thats not possible unless we talk -200 celsisus cold stuff.
1050mhz been tossed around.
This is all correct.
The bit you're missing is that the 8800GT was the next generation on from the 8800GTX, it's just they launched a non-flagship card first (in order to compete with the imminent HD3870) and decided not to change the series name. They did this after to add confusion, with the 8800GT becoming the 9800GT and the 8800GTS 512MB becoming the 9800GTX (just the 512MB GTS, the 320MB/640MB ones were older cards from the same series as the 8800GTX)
That isn't a straight rebrand.
Now tell me that's the same as releasing a card that has the exact same identical core as it's predecessor 2 years prior? It's not nearly as ridiculous.
Answer is you can't, because it's plain stupid. Hence the need for FITH to throw in cards that wouldn't have even existed until 12 months later as an example of direct competition lol.
Yes it is, when you overclock a card and change the name, that's a rebrand.
You need to read up on the G92 rebrands, the 8800GTS 512MB, 9800GTX, 9800GTX+, GTS250, GTS250 Green are all the same GPU rebranded with different clocks. The only notable change was that the 9800GTX+ was die shrunk (but it's still the exact same chip only smaller).
If they want to have memory clock as 6000MHz (1500MHz), they MUST use better memory, as the memories on the 290/x, not all of them can run stably beyond 5000MHz (1250MHz).Yes it is, when you overclock a card and change the name, that's a rebrand.
Back on the topic of AMD specific rebrands and not rebrands in general, does anyone know if they will be using cherry picked chips for lower power usage or better clocking or whatnot?
GT > GTS
You seem to poking a stick at me on the premise I care about the moral high ground.
I'm still hoping the the name change to the GPU would mean also some tweaking gone into the GPU itselfs as well to improve efficiency etc, ideally like how GTX480-> GTX570/GTX580 was...otherwise the change of name of Hawaii to Grenadier for the chip would be extremely stupid.
I wander if people would be so accepting of a GTX 970 type situation had AMD done that.. I think probably... No no they wouldn't.
Ive said it before, and i'll say it again, if AMD pulled a 970 vram-gate, everyone would be returning their cards, but not with the extra cash for the next card up ,oh no, it would be for a Nvidia card.
8800 GT was a cracking card, still got it somewhere![]()
That's add 8 hours, 7 hours would be mountain time in the USA. PST is 8 hours
Judging by the Sapphire specs there is no improvement on power draw. 375w and 2x 8 pin.
https://forum.beyond3d.com/threads/...series-speculation-rumor-thread.55600/page-94You understand the notion of reference specifications vs AIB/partner board specifications, yes?
I had an XFX one in a machine, but the fan died. Some things never change![]()
