- 3 Nov 2010
I have recently bought a sapphire R9 290 vapor x which comes OC'd at 1000 on the core and with effective memory clock of 5.6 GHz (1400 memory clock).
However i am having trouble getting much more out of it which is surprising.
I can get it running at 1100 on the core and 1450 on memory but anything higher and i get artifacts in game. Does having a low PSU have any bearing on clocking. The recommended PSU is a 750 w one but i am using my 600w one. (most reviews say a 600w is fine). Also do artifacts mean that damage is being caused to a card.
My card also seems quite hot - i know that these cards with stock coolers get to 95 degrees but mine when OC'd gets to 82 degrees when using automatic fan control. I have had to place my card on the lower pc express x 16 slot due to its size which means the fans are practically touching the bottom of my pc case. I can get lower temps if using a custom fan but thought that 82 was excess
