OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to introduce a new range of 80+ Bronze rated SuperFlower power supplies. The FX range are aimed at customers who wish to have SuperFlower quality in their builds but are restricted to a smaller budget. Each FX unit is built to the same high standard as the Leadex and HX ranges, yet are competitively priced within the market.
The SuperFlower Bronze FX Series provide stable and reliable power, and come with a 3 year warranty as standard for piece of mind, plus the 450W - 650W even support select dual VGA setups. These will be available by early next week, so feel free to pre-order now!
SuperFlower FX 350W '80 Plus Bronze' Power Supply - Black @ £34.99 inc VAT
The SuperFlower Bronze FX series PSU are 80+ Bronze certified with non-modular cables design. Bronze FX series PSU provides high efficiency & stable power output and come with a 12cm silent cooling fan to ensure your professional PC system will work under heavy load, and is also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
The SuperFlower Bronze FX Series aims to provide reliable SuperFlower quality with a more competitive pricepoint, allowing you to power your system reliably and safely.
Features
- Full Range Design 100V~240V (Active PFC)
- Support all Intel/AMD Multi-Core CPU (Haswell Compatible)
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Comply With ATX 12V. V2.3 Specification
- 80 PLUS ® Bronze Certified (82% 85% 82% Efficiency At 20% 50% 100% Rated Load)
- Grade A Taiwan Brand Capacitors
- OVP / OCP / OPP / SCP / UVP
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Unleaded Green Materials with RoHS/WEEE Compliance
- More than 2,000 times On/Off test
- PCI-E (6+2) Pin Connector For High-End Graphic Card Requirement
Specifications
- CPU: Support all Intel & AMD Multi-Core CPU (Haswell Compatible)
- Power: 350W
- Efficiency: 82% 85% 82% Efficiency At 20% 50% 100% Rated Load
- Fan: 120mm long life silent fan
- Frequency: 50/60Hz
- Safety: TUV / CB / CE / FCC / BSMI / RoHS
- Dimensions: 140(D) x 150(W) x 86(H) mm
- Housing Color: Black
- Weight: Around 2.0 KGS
- Cable: High Quality Fully Black PSU Cable
- Protection: Over voltage protection (OVP), over current protection (OCP), over load protection (OPP), short-circuit protection (SCP), under voltage protection (UVP)
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 6+2-Pin-PCIe
- 4 x SATA
- 2 x 4-Pin-Molex
- Warranty: 3yr
Only £34.99 inc VAT.
ORDER NOW
SuperFlower FX 450W '80 Plus Bronze' Power Supply - Black @ £42.95 inc VAT
Features
Specifications
- Power: 450W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3yr
Only £42.95 inc VAT.
ORDER NOW
SuperFlower FX 550W '80 Plus Bronze' Power Supply - Black @ £49.99 inc VAT
Features
Specifications
- Power: 550W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3yr
Only £49.99 inc VAT.
ORDER NOW
SuperFlower FX 650W '80 Plus Bronze' Power Supply - Black @ £57.95 inc VAT
Features
Specifications
- Power: 650W
Connectors
- 2 x 6+2-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- Warranty: 3yr
Only £57.95 inc VAT.
ORDER NOW
Features
Specifications
- Power: 350W
Connectors
- 1 x 6+2-Pin-PCIe
- 4 x SATA
- 2 x 4-Pin-Molex
- Warranty: 3yr
ORDER NOW
Features
Specifications
- Power: 450W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3yr
ORDER NOW
Features
Specifications
- Power: 550W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 3yr
ORDER NOW
Features
Specifications
- Power: 650W
Connectors
- 2 x 6+2-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- Warranty: 3yr
ORDER NOW
