- 5 Dec 2010
- The Moon
AMD shares boys.....
AMD shares.....
AMD shares.....
Unless its the dual card the Titan X will still be fastest. However if its faster than the Ti then they are onto a winner at that price.
The Nano is pretty awesome too.
45fps was in 5K
So £500 for a card that might be slightly quicker than the 980Ti assuming the benchmarks back it up, but still 300W or so?
Just googled and it seems about the same as the 980Ti?
http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_980_ti_review,17.html
Reading between the lines the Fury X will compete directly with the 980 Ti on price and performance.
Was it? Sure they said the Fury X was $649, or is the Fury the same thing but on air?That is the water cooled version. Aircooled one should be under £400 I think.
Also some new tech. HBM![]()
Well their dual GPU will but I have a feeling Nvidia will release a dual Titan X card soon.
Titan x only does 26 fps on Tomb Raider at ultra details on 4k. If the fury x does 60 fps then AMD have nailed it
Probably a a few percent faster than a R9 290X but at half the wattage,so it has around twice the performance per watt.
Im going Fury X!![]()
