Hi Guys
Our finger is so on the pulse it has blocked your artery!
OcUK are first to bring you pre order status of the incredible new Mouse line from Razer.
Mamba was an enormous success for us as the first genuinely lag free wireless gaming mouse available. The mamba 2012 followed this up with lighting customisations that had never been seen on peripherals as well as upgrades to the internals to make it even better. I should know, I had both and they were fantastic.
Razer have upped their game again with the introduction of Mamba Chroma.
The new Mamba mice from Razer are based on a new design featuring an immense new sensor as well as optimisations to the shape. Included in this premium flagship product is Chroma lighting for those looking to customise their desktop too.
The Mamba comes in Wireless as before as well as a Wired Tournament edition for those looking for epic performance but need even lower latency than the wireless version.
Both models have no ETA into the UK at the moment but OcUK are working closely with our Razer partner to ensure that we have the stock available the moment it is physically here.
Razer Mamba Chroma Wireless Professional Gaming Mouse @ £129.95 inc VAT
The world's most precise gaming mouse sensor with 16,000 dpi
Boasting the world's most precise 16,000 dpi gaming mouse sensor, the razer mamba provides you with unsurpassable accuracy, so you'll have an even greater edge over your competition. With its ability to track 1 dpi increments and a lift-off cut-off distance as precise as 0.1 mm, the razer mamba helps you to react instantly while you skillfully maneuver your way to victory.
Revolutionary adjustable click force technology* for personalized click feedback
Whether you prefer a lighter rapid fire click or fuller distinctive click, the razer mamba's hyperesponse buttons come with an adjustable click force mechanism which allows you to tweak them to your exact needs. Choose between different levels of actuation force to set up your personalized click feedback, whether it's higher for controlled sniping or lower for rapid fire clicks during heated moba battles.
Industry leading gaming grade wired/wireless technology for unbridled maneuverability
Engineered with industry leading gaming grade wired/wireless technology, the razer mamba gives you completely unrestricted movement without compromising on control or accuracy. Wired or wireless, the razer mamba delivers a response rate of 1 ms, allowing you to enjoy peak performance at virtually zero latency. Furthermore, you can still use the razer mamba while it's charging, so you never have to deal with downtime even during the longest gaming marathons.
Features:
- Wireless mode
- 16,000 DPI 5G Laser sensor
- Adjustable Click Force
- Tilt-click scroll wheel
Chroma Lighting Zones:
- Scroll wheel
- Side strips
- Charging Station
Specification:
- 16,000 DPI 5G laser sensor
- 210 inches per second / 50 G acceleration
- Dual gaming grade wired/wireless technology
- 1,000 Hz Ultrapolling / 1 ms response time
- Adjustable Click Force Technology
- Ergonomic right-handed design with textured rubber side grips
- Chroma lighting with true 16.8 million customizable color options
- Inter-device color synchronization
- Nine independently programmable buttons with tilt-click scroll wheel
- Charging dock
- Razer Synapse enabled
- 2.1 m / 7 ft braided fiber USB charging cable
- Approximate size: 128 mm / 5 in (Length) x 70 mm / 2.76 in (Width) x 42.5 mm / 1.67 in (Height)
- Approximate weight: 125 g / 0.27 lbs
- Battery life: Approximately 20 hrs (continuous gaming)
Only £129.95 inc VAT.
ORDER NOW
Razer Mamba Chroma Tournament Edition Professional Gaming Mouse @ £79.99 inc VAT
Boasting the world's most precise 16,000 dpi gaming mouse sensor, the razer mamba tournament edition provides you with unsurpassable accuracy, so you'll have an even greater edge over your competition. With its ability to track 1 dpi increments and a lift-off cut-off distance as precise as 0.1 mm, the razer mamba tournament edition helps you to react instantly while you skillfully maneuver your way to victory.
Ergonomic form factor for complete comfort
Designed for the most natural hand position, the razer mamba tournament edition boasts impressive ergonomics that reduce stress on your fingers when you're actuating buttons and eliminate unnecessary finger drag points. Whether you're training for a tournament or playing an overnight raid session, your razer mamba tournament edition gives you an extremely comfortable gaming experience the whole time.
Taking personalization to the next level, you can now illuminate the razer mamba tournament edition's ths logo, scroll wheel, and side strips just the way you want. Each lighting location is individually customizable, allowing you to have a variety of lighting effects and the full spectrum of 16.8 million colors for an impressive displays that's as unique as your play style.
Features:
- Scroll wheel
- Side strips
- Razer Logo
Specification:
- 2.1 m / 7 ft braided fiber USB cable
- Approximate weight: 133 g / 0.29 lbs
Only £79.99 inc VAT.
ORDER NOW
Features:
- Wireless mode
- Scroll wheel
- Side strips
- Charging Station
Specification:
- Charging dock
ORDER NOW
Features:
- Scroll wheel
- Side strips
- Razer Logo
Specification:
ORDER NOW
