last word is a noobs weapon it takes no skill to use IMO. hawkmoon is the true skillers hand cannon where you actually have to pick your shots and aim properly. thorn is far too powerful for what it is and another noobs weapon, the burn or range needs to be nerfed on it.
no way should someone be able to hit you in the head from 30 feet away without aiming and just spamming the trigger. it should be a lot more unstable than what it is especially since your not aiming it and spamming the trigger all the time.
if you want to get good at pvp though the gun i would recommend practicing with is hawkmoon. it takes real skill to use as you need to aim and you need to aim for the head to win encounters.
if you want to win by exploiting the mechanics then run thorn, sniper with final round and a rocket launcher with tracking and horseshoes. i think i'm just peeved i never got into sniping in PVP before. having one of those snipers now would be like taking candy from a baby.
Tend to agree, while it takes skill using them they are lethal. I wouldnt say one is better than the other, just depends on the situation. Thorns perk is very useful though...I think all hand cannons are a touch OP in the Crucible. This is shown by just how many of the top players use them. I wouldn't say that one is head and shoulders above the others though. I rotate between Thorn, Hawkmoon and The Last Word, depending on my mood and the map, and my KD is fairly consistent across all 3 of them. My personal favourite is Hawkmoon simply because that ultra-rare one shot kill is a thing of beauty.
I need to start using Mida in PvP more I think. In some of the longer range maps where snipers rule I think the extra stagger effect it has will be really useful.
explain how using a gun like the last word, where you don't have to aim down the sights on a handgun. can rapidly shoot 7 bullets with next to zero feedback/pull up from the gun is not a noobs weapon? it's also completely devastating at mid range. that type of gun should either have massive stability issues or be useless at anything beyond 15 feet. the gun just doesn't make any sense.
thorn is a noobs weapon because of the burn. take the burn away and it would take skill to use. with the the burn all you need to do is shoot them a few times and wait for them to die. or hit them once pop into cover and through a nade over in their general direction.
my current loadouts are
thorn
red death
hawkmoon
one of the above as primary depending on map
felwinters lie
praedyths revenge
You complain about noob guns yet you use Thorn and Felwinters Sniper? Irony much?
that's because they are OP compared to others so obviously i'm gonna use them.
before the last round of nerfs i used to solely use vex and red death, never used handguns at all. the last patch made me switch to hawkmoon and thorn.
also felwinters is a shotgun not a sniper. the sniper is called idiots spear
praedyths is the sniper i use
Hah, I'd like to play against people who stand stationary enough for the auto aim to track them. All I seem to play against are blinking hunters with shotguns.The Last Word is definitely a noob weapon because I was using it. LMAO. All you have to is connect with the first hit and the auto aim will then take over and guide the rest of the magazine when you hold the trigger.
That's not just The Last Word though, the game in general has fairly generous auto aim. With the way it can spray though, TLW is definitely set up to take advantage of it. Suros used to be the same before the nerf.That's what I mean though. People were running across my field of view and you could literally feel the aiming pulling your sights to keep them on target. I was amazed at some of the shots I got. They defied belief on some occasions.
Yeah, that's the first time I've ever heard Efrideet's Spear referred to as Idiot's Spear, and I spend a ton of time on the Destiny Reddit where most of the pet names in the game come from. Sonny in making stuff up shocker?Yes it is a shotgun often nicknamed Felwinter's sniper due to its kill range.
idiots spear is a new one..
Could you imagine the backlash if they changed the Final Round perk on all the guns people already have? There would be absolute mayhem on all forms of social media. Bungie are stuck because they know it's an OP perk when abused, but they can't really get rid of it. I think that might be why they introduced the Hidden Hand perk, which gives you better aim assist. It makes it a lot easier to land head shots which effectively counters Final Rounds.
