Hi all,
So my iMac etc goes up for sale on eBay shortly. I'll be looking to use the money from that to fund a MacBook Pro, currently undecided on a retina model or otherwise.
Pros for Retina
But obviously those pro's all come at a premium. I'm going to be using it for travelling so portability is an absolute must for me. However the normal 13.3" MBP is hardly big or heavy so I've no issue with that.
So what I'm focusing on is a couple of things, the main one is grunt. What spec is yours? Retina or Non. How do you find the image processing/general Lightroom usage. Do you find it slowing down? Do you wish your spec was better, and if so in what way?
Also, the Retina screen. The initial benefits are obvious with general usage. However, do you find this a genuine benefit when image processing? Does LR take advantage of the Retina displays? I dont find the 'standard' displays from Apple products to be bad by any standards so am considering going for a standard screen. But then it brings back to then carrying a heavier laptop around.
My minimum specs are 16GB RAM and 256gb storage. Processor wise I'd be happy with an i5 2.6ghz or upwards. An i7 would be amazing but it depends on what's available.
I'll be looking into Cloud storage for my 'keeper' photos from traveling and it'll be handy when on the move. If you use cloud storage, who do you use/recommend?
What say you, good sirs!
Pros for Retina
- Dat screen with dem pixels. Duh
- Weight
- Portability
- It's kick-ass
