- 29 Dec 2009
Do you have a hardware firewall, what do you use it for generally?
Yes I use one, it is built into my MikroTik, not technically a "hardware" box in the sense I think you are asking OP as I think you are asking does anyone use a "dedicated" firewall box.
I use mine for basic duties however will implement an additional software firewall on my soon to be MikroTik RB2011 set as a WAP so I can create a guest wireless network so it can only run port 80,443 and DNS (forgot number)
Cisco ASA, Sonicwall, Netscreen etc.
Is this some sort of homework question ?
ASAs are NOT based on IOS, they are an evolution of PixOS.
A lot of the same structure though only customise to the function of the box
Pixes are horrendous things, they stepped up with the asa's
What I was trying to point out, its better to have a dedicated hardware or virtualised appliance running what you need rather than software on top of base os
I have no doubt checkpoint sits on other platforms but its bare metal stuff sits on Linux based platforms, freeBSD, gentoo for a few examples
