AIO cooler for 980ti EVGA or Corsair
NZXT G10/s with corsair H55's
What I found a good tip if you dont have double fans on your rad is to get one of the fan dust filters thats detatchable and fit it the front of the radiator. That way the dust doesnt get into the radiator as much and you can just detach the fan filter and clean it without having to unscrew it.
yeh it snot like that anymore its full custom loop so all good now.
The one I'd really like to try, and surprised no one has done anything similar is the Swiftech MCR140-X Drive. Pump is built into radiator and allows full gpu blocks!!
