980ti Zotac Amp EXTREME
10 Dec 2012
Anyone yet found a review/preview of this card?
The clocks on it look absolutely insane.
It is a triple slot card but if you only want a single card solution this looks great.
Just a bit worried it will destroy itself in it's quest for glory.
edit - its something like 25% over the standard clocks.
They certainly do look insane:
And yes, that is over 9000 ;)
The factory OC is immense but I think I can settle with the MSI Gaming 980Ti. I like the fact that Gigabyte and MSI have used a custom PCB with 2x8Pin. The Amp and Amp Extreme have a reference PCB. If anything, with luck I'll be able to OC the extra 80MHz the Extreme has, unless I have no headroom.
The extreme is a custom pcb as well, the info on the ocuk website is incorrect
Hopefully there'll be stock of msi's coming in soon. Heard that later this week is a possibility. G1 seems like too dog at the moment going by reviews. Two cards that will be very interesting are the evga classified and the msi lighting.
