*** ANTLION Audio Omni ModMic Stock Landing Soon***
7 Feb 2011
Stoke on Toast
I have added 2 new ModMic Sku's to the range.
These offer a more sensitive microphone with better frequency response but at the cost of noise cancelling.
ANTLION Audio Omni Modmic 4.0 @ £39.95 inc VAT
The Omni-directional capsule offers better frequency response and sensitivity than the Uni-directional capsule but does not offer as much noise-cancelling.
Generally, if you don't need noise suppression/cancelling, go with the Omni-directional.
Contents:
One Omni-directional ModMic (with mute button)
Two base clasps, one top clasp with cap
One extra 3M pad for re-attachment of base clasp.
One foam pop filter
Alcohol wipe
5 cable clips (not in pictures)
Instructions
Carrying case
Product specs:
Jack: 3.5mm plated TRS for use with PCs
Xbox One: works fine through controller via a CTIA/TRRS adapter. Will need latest firmware update! (as of 5/22/15)
Play Station 4: works fine through controller via a CTIA/TRRS adapter. Sounds strange at times if used through mixamp.
Mac/PS3/Xbox 360 headset jacks with proper adapter (Macs will need a USB adapter)
Cable: 3.3 meters length, 2.5 mm diameter, coaxial shielding, mute button ~150mm from end of boom (about shirt pocket height)
Boom: 175mm max length, very bendable with internal steel spine
Clasp: 12.7mm (0.5 inch) diameter circle adhesive pad footprint, ~17.5mm total height of attached clasp assembly.
Microphone capsule specs:
Pattern: Omni-directional
Response: 30 Hz-17.5 kHz ± 3 dB
Sensitivity: -26 ± 3 dB
SNR: 58+ dB
Impedance: 2.2 K-ohms
Max current at 2.0V: 500 µA
Max input SPL: 110 dB
Only £39.95 inc VAT.
ORDER NOW
ANTLION Audio Omni Modmic 4.0 (muteless) @ £34.99 inc VAT
If you're going to use your mic in a quiet area and you don't need noise suppression/cancelling, go with the Omni-directional.
Contents:
One Omni-directional ModMic (no mute button)
One foam pop filter
Alcohol wipe
Instructions
Carrying case
Product specs:
SNR: 58+ dB
Only £34.99 inc VAT.
ORDER NOW
the microphone doesn't need a firmware update the xbox will not confusing it's microsoft.
I think for this price, I'd have wanted to see a braided cable instead of the basic black plastic.
Still, you have em for a good price with those AKG headsets, so all is well.
