Comet was always labelled as an 'expansion game' so that link is still largely valid
ps3ud0![]()
Anyone feel like crucible needs another weapon rebalancing? It's definitely better since launch, but still ended up with some balancing issues.
I'd like to see hand cannon range reduced. The damage is fine but they shouldn't be popping people's heads at sniper range. There's very little point using a scout rifle at the moment because handcannons hit harder and have the same effective range.
Auto Rifles could do with a tiny impact buff to make them viable again.
Not sure what to do with Fusion Rifles....the appearance of long range shotguns and the increased fusion spread has made them a bit pointless.
Yup, I said the same a few days ago. I think you only have to look at how many people use hand cannons to see how OP they are. Obviously there are exceptions such as shotguns at close range or snipers at looong range but in in auto/scout/pulse rifle range, hand cannons will win everytime.
In most FPS I tend to use burst fire or single shot weapons so actually like using hand cannons but it would be nice to have the choice to use other weapons.
It'll confuse people referring to a 'Standalone Expansion', which it isn't anymore. It's DLC, you need the original game to play it, whether you have it already or buy it all in the Legendary Edition bundle.
Does everybody know Destiny is down from 4pm to 10pm tonight for a 6 hour maintenance window ?
Anyone having trouble connecting? I keep getting a "tapir" error.
See above, servers down for like 6hrs
does anyone use any other exotic other than gjallahorn in PvE?
obviously if you don't have it the question doesn't apply.
people complain about pvp a lot but they need to either nerf gjallahorn or buff every other exotic there is in pve.
i have stopped using the vex since the last nerf it's absolutely rubbish now. the only time i don't use gjallahorn is when there is arc or void burn on.
i suppose the exotic shotguns don't need a buff but all other weapons do.
Nice of Bungie to warn people about these server downtimes, isn't it.
