looking to upgrade from a AMD 7850 2GB
which you recommend for gaming 390 or 970?
thanks
r9 390 easy, especially as video ram is becoming more important now as devs use it more, also its faster, simple.
8gb is just not needed for 1080p
And 3.5gb isn't enough in some games at 1080 now.![]()
VSR/DSR. The monitors resolution question is becoming obsolete due to this but to be fair to you EasyRider, it's not like everyone uses it so it's still relevant.
I game in 1080p but would like to upgrade to 1440p by the end of the year, i would be going with the non X version
so i'll go with the 8GB 390, any recommended make i should buy?
thanks for the reply s btw
VSR is crap, it doesn't even go to full 4k on the 290x! Only the 285 and the new cards get full 2160p!![]()
