Ah, nice. Out of curiosity, how much clearance do you have between the top of the res and the case? Would the 140 variant of the pump/res combo fit in there or does it have to be 100?
Stupid question - These fittings came with a bag of o-rings, do I need to put these around every fitting?
Going to get a 1mm drill bit tomorrow and see if I can get it out that way, continuing on with other parts ATM as Maplins is closed
Got it all sorted
Btw, the threads on my CPU block don't all seem to go in as far.. The provided guide suggests to screw them hand tight but the one in the top left corner doesn't seem to go as far as the others. Will that matter?
