Out of interest, who implemented the GameWorks features? Did it fall on the 3rd party (essentially) contractors?
GameWorks arguments don't belong here, this is a publisher moving a AAA title over to likely some Eastern European group to do their work for them because we aren't a priority. It's disgusting.....
The "Eastern European" guys at CDPR did a fine job of The Witcher 3 so your comments are, shall we say, not adding very much to the debate.
Plays fine on my PC. 3440*1440, everything max, 5960X and two Titan X's. Showing VRAM usage up to 7GB at times and 50-60 fps. I'll have to double check GPU usage the next time I check but I'm enjoying it so far.
Yes, more often than not NVIDIA will have onsite visitation but not always.
It is up to the developers:
- How they implement GameWorks effects
- To evaluate the performance of GameWorks effects and optimise
- Which effects the game can make use of
Don't be coy. The point was valid as the money involved will be less than involving a party elsewhere. The only thing you're adding is insinuating I was making a racist remark but that's clearly how you tick in that case.
Developers from the Ukraine and other neighbouring countries, who by the way I have worked with before on various projects, have you? - Will quote for substantially less than if you were to outsource to a neighbouring firm in the UK. So yes it was adding something you have an inclination into the European economy, thanks.
The fact you felt the need to edit your post with that addition speaks for itself.
What addition and how does any of it change my angle? Ok you carry on making no sense that's fine by me. I'll break it down, you saw me mention a certain part of the world and instantly in your head you thought "tsk, that's not on".
Well that's good for you, learn more. Good day to you![]()
If you think condescending replies intent on having the final say excuses your arrogant casual racism, then that's between you and your conscience.
Everyone can see what you wrote, I don't need to labour the point any further.
Hi, if your understanding of an SDK you've never seen is as limited as your one of a PCB and vregs you've never seen then I kneel before your superior misinformation.
GameWorks arguments don't belong here, this is a publisher moving a AAA title over to likely some Eastern European group to do their work for them because we aren't a priority. It's disgusting, and pointing fingers at your least favourite hardware vendor is narrow sighted here.
If Rocksteady don't care what happens to the PC version you've got a cat in hells chance of anyone else's being able to do anything about it.
How is that fine??? It's a graphically undemanding title where the PS4 / XB1 versions enjoy greater graphical fidelity than the PC @ all Ultra.
Gameworks implementation would mean that Nvidia was involved in game production as well. Since they claim that they work with developers to implement gameworks, it also puts some of the blame on them. If they worked with the developers on AK, they must have known how poor the port was, yet they still allowed it to be released and used it to promote gameworks.
