Full price gear delivered without box?
24 May 2011
Is it normal for something like a D5 pump to come in an envelope rather than a retail box? I also got sent a rather expensive PCI-E m.2 card wrapped in bubble wrap? Is this normal?
Not sure about the M2 card,but my D5 from OCUK also came packaged in an envelope(which was in a bigger box including other gear),its normal for packaging from what i can tell
Mine works fine :)
ok thanks for the reply. I wont be able to try it for a few weeks... hope its ok. I also hope the M.2 card is ok because it was rather poorly packaged.
If the card is OEM then these usually only come in a Anti-Static bag and then protected for shipping.
Similar applies to Hard drives, optical drive, CPUs and even GPU's. my old 8800GTX was just shipped in protective wrapping.
I know this but the card is NOT OEM. It was a full price purchase and does not state OEM on the website.
Can you link to what you bought? Was it new or out of the b grade section? is there any box with the card or just a anti static bag and bubble wrap?
Found a review for the drive,in it it says this
Just as its AHCI bother there is no retail packaging. On the front you have the product sticker and the back is bare. The firmware revision we are testing with today is BXW7000Q. Overall, the thickness is under 4mm and it weighs in under 7g.
Hello, as another forum member has mentioned the drive is OEM as so are most of our drives unless stated as retail.
If you have further questions post in our customer service section here :)
