Hello all,
I have a 2013 BMW 320d which has covered 32k miles and is fitted with Bridgestone Potenza S001 Runflats on 18" wheels.
The rear tyres have plenty of life left (4-5mm) however the front tyres are wearing unevenly. The outer edges of the tyres are wearing faster than the rest of the tyre with the drivers side being the worse of the two. The centre of the tyres has approx 4mm left whilst the outer edge is approaching the limit. I have checked pressures and all are to manufacturer's spec.
I have read a number of things, that outer tyre wear is a trait of runflats and replacing with non-RF solves it, alignment could be out...etc.
Does anyone have any experience of this issue (particularly on BMW's) and can advise? I'd like to get this solved before fitting new tyres.
Thanks in advance.
Thanks in advance.
