OcUK Staff
- 26 Nov 2014
- Stoke
We've decided to introduce the XFX XTR 750W and 850W 80+ Gold Modular PSU's into our range at competitive pricepoints. These are rebadged Seasonics and represent excellent value for money for the spec you are getting, along with coming with a 5 year warranty as standard.
XFX XTR 750W '80 Plus Gold' Fully Modular Power Supply @ £89.99 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 750W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
It's also been awarded the 80Plus Gold certification for its high power efficiency, and is also designed for NVIDIA SLI and AMD Crossfire multi-GPU systems, making it a perfect solution for hardcore gamers. Its modular design reduces cable clutter. And the large fan delivers silent cooling, so your computer and PSU can operate at peak performance.
Features
- EasyRail™ Plus Technology allowing plenty of wattage headroom to handle your devices
- Hybrid Fan Control allowing the power supply to operate silenty until it reaches 20% load or 25°C
- Ultra Quiet Fan Design
- Ultra Voltage Regulation Design
- Haswell Ready
- AMD Radeon CrossFire Ready
- NVIDIA GeForce SLI Ready
- Multiple PCI-E 6-Pin and 6+2Pin connectors
- True Wattage guarantee
- 80 Plus Gold certifying 90% power efficiency
- Extreme heat tested capacitors
Specifications
- +12V Rail Outputs : Single
- 100% Tested and Verified : Y
- ATX12V 2.2 & ESP12V 2.91 Compliant : Y
- Maximum Wattage (W) : 750
- Modular Cables : Y
- Performance Category : Enthusiast
- UPC Number : 778656058804
- CrossFire Ready : Y
- SLI Ready : Y
- AC Input Current (Arms) : 9.5A-4.5A
- AC Input Frequency (Hz) : 50/60 Hz
- AC Input Voltage (Vac) : 100-240
- Efficiency @ Typical Load : Up to 90%
- Energy-Efficiency : 80 Plus Gold Certified
- High Reliable 105°C Japanese Capacitors : Y
- Solid State Capacitors : Y
- Tight voltage regulation (±5%) : Y
- Max -12V Output Current (A) : 0.3
- Max +12V Output Current (A) : 62
- Max +3.3V Output Current (A) : 20
- Max +5V Output Current (A) : 20
- Max +5VSB Power (W) : 2.5
- Modular ATX12V / EPS12V : One 4+4-pin, One EPS 12V 8-pin
- Modular FDD : 1
- Modular Motherboard Connector : 20+4-Pin
- Modular Peripheral : Up to 6 Connectors
- Modular SATA : Up to 10 Connectors
- Active Power Factor Correction (PFC) : Y
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Y
- Cooling Fan Size (mm) : YES; 135mm Fluid dynamic Fan (Black)
- Master Carton Dimensions (cm) : 43.0 x 29.5 x 34.0
- Master Carton Dimensions (inch) : 16.93 x 11.6 x 13.39
- Master Carton Weight (Kg) : 11.72 est.
- Master Carton Weight (lb) : 25.84 est.
- Package Dimensions (cm) : 31.9 x 21.0 x 16.3
- Package Dimensions (inch) : 12.55 x 8.26 x 6.42
- Package Weight (Kg) : 2.76 est.
- Package Weight (lb) : 6.08 est.
- PSU Dimension (cm) : 8.6 x 15.0 x 17.0
- PSU Dimension (inch) : 3.4 x 5.9 x 6.7
- Units per Carton : 4
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £89.99 inc VAT.
ORDER NOW
XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply @ £99.95 inc VAT
Designed for serious gamers and DIY professionals, the XFX XTR Series 850W Full Modular 80 Plus Gold power supply delivers the clean and stable power required for demanding gaming rigs and workstations. A single strong 12V rail flexibly routes the maximum available power to the parts, enabling you to maximize power usage and making setup easy.
Features
- Haswell Ready
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Electrolytic Capacitors
Specifications
- ATX12V 2.2 & ESP12V 2.91 Compliant : Yes
- Maximum Wattage (W) : 850
- UPC Number : 778656058811
- CrossFire Ready : Yes
- SLI Ready : Yes
- AC Input Current (Arms) : 11A - 5.5A
- AC Input Voltage (Vac) : 100 - 240
- Active Power Factor Correction (PFC) : >0.95 at full load
- DC Output Voltage Regulation : ±3%
- DC to DC Converters (+3.3 & +5V) : Yes
- EZ Grip Connectors : Yes
- High Reliable 105°C Japanese Capacitors : Yes
- Solid State Capacitors : Yes
- Max -12V Output Current (A) : 0.8
- Max -12V Power (W) : 6
- Max +12V1 Output Current (A) : 70
- Max +12V1 Power (W) : 840
- Max +3.3V & +5V Combined Power (W) : 125
- Max +3.3V Output Current (A) : 25
- Max +5V Output Current (A) : 25
- Max +5VSB Output Current (A) : 3
- Max +5VSB Power (W) : 15
- Max. +3.3V & +5V combined power (W) : 125
- Wattage(W) : 850W
- Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection, Over Voltage Protection (OVP), Short Circuit Protection (SCP), Under Voltage Protection (UVP) : Yes
- Cooling Fan Size (mm) : 120
- Intake Fan: Airflow (CFM/min) : 80.5
- Intake Fan: Diameter (mm) : 120 x 120 x 25 mm
- PSU Dimension (cm) : 8.6 x 14.0 x 16.0
- PSU Dimension (inch) : 3.4 x 5.5 x 6.3
- RCM : Yes
- CB : Yes
- cTUVus : Yes
- TUV: Yes
- CCC: Yes
- FCC: Yes
- CE: Yes
Connectors
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 6x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
Features
- Haswell Ready
Specifications
- SLI Ready : Y
- Modular FDD : 1
Connectors
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features
- Haswell Ready
Specifications
- SLI Ready : Yes
- Wattage(W) : 850W
- RCM : Yes
- CB : Yes
- cTUVus : Yes
- TUV: Yes
- CCC: Yes
- FCC: Yes
- CE: Yes
Connectors
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 6x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
